Originally Posted by
Reedy
On this date and time my car had been sat all day at work from 7.30 to 4.00 approx. All I did is return to the car unlock it, get in and start it. That’s when all the se faults came up and as I drive off they go away one by one except the front radar, I have to turn the car off and then back on for this to work properly. They are aged as I’ve only just got round to clearing them yesterday and it’s not happened since that date.
^^^ ^hmm........ OK. Fact is though that the DTC is quite specific (Cruise Control Front Distance Range Sensor separated). So, either the module is lying, or it really happened through someone else's intervention, or it resulted from a loose wire/connector.
But this really doesn't matter for the purposes of the discussion. There were no "low battery volts" errors on your scan report. By all means, change the battery if you want - but do it because of a concern about its age, rather than as a result of a need from a diagnostic scan report!!!
