Looks like typical voltage weirdisms to me.
If you have a decent battery charger it might be worth seeing if the battery can be recovered, but in reality they are a consumable item in this world of stop/start systems. 5 years isn't too bad though.
Hey folks. Twice in the past 2 months after the car has been sat all day at work (8hrs) on start up all these faults pop up and gradually they all go away as I start to drive off. They look like communication errors so I’m thinking my battery is on its way out. It’s never happened in a morning in the garage but only after work. Car seems to start fine with no hint of a struggle but the last time it went there was no warning. I remember my mk6 GTI through lots of faults when it was about to go but not this R. Any other thoughts would be greatly appreciated or should I be looking for a new battery sooner rather than later?
OBDeleven data log
Date: 2020-07-08 10:30
VIN: WVWZZZAUZFW075389
Car: Volkswagen Golf R
Year: 2015
Body type: 5-dr hatchback
Engine: CJXB 206 kW (280 HP) 2.0 l
Mileage: 151043 KM
76 Parking Assistance
System description: PARKHILFE 8K
Software number: 5Q0919294E
Software version: 0048
Hardware number: 5Q0919294A
Hardware version: H03
Serial number: 39331420700621
ODX name: EV_EPHVA18AU3700000
ODX version: 002024
Long coding: 0071151001
Trouble codes:
U112300 - Databus error value received
Intermittent
OBDeleven data log
Date: 2020-07-08 10:24
Year: 2015
Mileage: 151043 KM
01 Engine
System description: 2.0l R4 TFSI
Software number: 5G0906259E
Software version: 0003
Hardware number: 06K907425B
Hardware version: H13
ODX name: EV_ECM20TFS0205G0906259E
ODX version: 001003
Long coding: 091900322446050B3000
Trouble codes:
Intermittent
OBDeleven data log
Date: 2020-07-08 10:23
Year: 2015
Mileage: 151043 KM
03 Brakes
System description: ESC
Software number: 5Q0907379CK
Software version: 0472
Hardware number: 5Q0907379G
Hardware version: H31
Serial number: 62024000001320
ODX name: EV_Brake1UDSContiMK100IPB
ODX version: 033001
Long coding: 01FA93A154272971037A070841CC6980C92A94C0E08296F7F4 4050B8C008
Trouble codes:
B1168F2 - Steering angle sensor no initialization
Intermittent
C114602 - Tire pressure monitoring display Signal error
Intermittent
OBDeleven data log
Date: 2020-07-08 10:19
Year: 2015
Mileage: 151043 KM
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655AA
Software version: 0386
Hardware number: 5Q0959655AA
Hardware version: 014
Serial number: 003MLR07KVHJ
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002130
Long coding: 98CCC000000000005C00000000C800000065
Subsystems:
System description: BeltPretRevFL
Software version: 0341
Hardware version: H35
Serial number: 34169677B31071441382
Long coding: 333135
System description: BeltPretRevFR
Serial number: 34169676B30071471086
Long coding: 333135
System description: SideSensor_Df
Software version: 0887
Hardware version: 001
Serial number: 3576700000057838A01R
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 358670000007CB8C6010
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 6149
Serial number: 35165029916DB80431CD
Long coding: 2D2D2D
System description: SideSensor_Pr
Serial number: 3526502B51656B92B07B
Long coding: 2D2D2D
System description: FrontSensor_D
Serial number: 3556502C516DB80592EQ
Long coding: 2D2D2D
Trouble codes:
Intermittent
Date: 2020-06-18 15:56:10
Mileage: 149701 km
Priority: 6
Malfunction frequency counter: 1
Unlearning counter: 200
OBDeleven data log
Date: 2020-07-08 10:17
Year: 2015
Mileage: 151043 KM
13 Adaptive Cruise Control
System description: ACC Bosch MQB
Software number: 5Q0907572D
Software version: 0304
Hardware number: 5Q0907572D
Hardware version: H05
Serial number: 31071476510988
ODX name: EV_ACCMRRBoschVW372
ODX version: 001015
Long coding: 00000300FE0739
Trouble codes:
Intermittent
Date: 2020-06-18 15:56:08
Mileage: 149701 km
Priority: 6
Intermittent
Mileage: 149701 km
Priority: 6
Intermittent
Mileage: 149701 km
Priority: 6
B10E7F0 - Cruise Control Front Distance Range Sensor separated
Intermittent
Mileage: 149701 km
Priority: 6
Unlearning counter: 201
OBDeleven data log
Date: 2020-07-08 10:16
Year: 2015
Mileage: 151043 KM
ODX version: 001015
Trouble codes:
Intermittent
Mileage: 149701 km
Priority: 6
Intermittent
Mileage: 149701 km
Priority: 6
Intermittent
Mileage: 149701 km
Priority: 6
Intermittent
Mileage: 149701 km
Priority: 6
2015 Golf R. Lapiz Blue.
Had the same in a Passat Battery for sure
When the OBDEleven connects to the car what is the battery voltage and is the icon green, orange or red.
Time for a new battery. 5 years and 150,000km is very good going from the original battery. Here is a suitable replacement to suit the Mk7 R: Buy Delkor LN370EFB (DIN65LH) 12V 720cca Automotive Battery | Delkor AGM Batteries
This is my second battery. 1st one went about 3 years ago and got it replaced under warranty. Thanks again for advice. I had a feeling it was going to be the battery just wanted to confirm. On my obdeleven the battery voltage is 12.6 and that’s after a drive.
Reedy: hi. I apologize in advance for not agreeing with other responses, and your battery may well be approaching the end of its useful life - but I very much doubt that the DTCs in your scan report were caused by this problem.
The principal reason for my doubt is that your scan report is full of what I call "aged errors" and more particularly because of the single date stamp that permeates ALL DTC records.
The odd thing about the DTCs on your scan report and the reason why they are "aged errors" is the date/time, itself and the fact that the Malfunction frequency counter= 1. This combination means that ALL faults in the scan were first recorded on the CAN network in the car on a single day/time and the faults have NOT been re-recorded on any subsequent ignition cycle up to the time that you made the scan report
So - what happened to the car on Thursday the 18th June 2020 @ a little before 4PM? According to the hex13 module, someone appears to have detached the front facing radar (this is the hex13 module) from the car! It appears from my reading of your scan report that this act has resulted in the loss of the steering angle reference calibration from the Brake module as well as the generation of a number of Database anomalies in multiple modules. Please advise
I might well be wrong (I often am), but this simply doesn't look like a battery problem to me!
