Results 11 to 20 of 23
Thread: New features that you discovered...Good/Bad
    Mar 2015
    Warner, QLD
    Here's an image
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
    Jun 2009
    Western Australia
    I'd neglected to explore these settings,cheers!
    Sent from my SM-G930F using Tapatalk
    Mar 2009
    Bad; Due to the body's overly hexagonal shape angling outwards & down, if it stops raining & you want to open the front windows, you'll get drops of water fall from the roof/top window sill inside the car onto the armrest. Luckily they miss any electric mirror switches.
    The rear windows tend not to leak this way I've found.
    MY16 MK7 Golf GTI
    - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
    Jun 2009
    Quote Originally Posted by agentthumb View Post
    Here's an image
    You've beat me to it. I do wish there is an option to have the ambient lights like the door lights, ie turns on when you open the door and fade off when you start the engine.
    GOLF V GTI DSG Silver : On loan to parent until wife thinks I am a responsible driver
    GOLF VI 118TSi DSG Silver Leaf
    GOLF VII 110TSi DSG White
    GOLF VII GTI pp : on negotiation
    Jun 2009
    hahaha, more of a "manly" look, I remember taking off in my car after the rain with the windows down. The water drips in from the roof, hits the windows controls a few times. But either switches are water sealed or I dry it before it got any deeper.
    Jun 2016
    Surry Hills, NSW
    I like the auto-down feature on the passenger's side mirror when you're in reverse. Don't forget to turn it on under Car and also have your wing mirror adjuster set to L (I think!).
    Jun 2009
    Quote Originally Posted by timgriffin View Post
    Spot on, took me a while at first because I didn't move the mirror nob to the L position. There is a complicated setup procedures in the manual to make the mirror dip down to the level you want.
    Storing front passenger exterior mirror settings for reversing
    Select a valid vehicle key on which the settings should be saved.
    Unlock the vehicle using this key.
    Switch on the electronic parking brake.
    Switch on the ignition.
    Put the gearbox into neutral.
    For reverse gear exterior mirror lowering function press the CAR button and the SETUP and Mirrors and wipers function buttons in the infotainment system → Menu and system settings (SETUP)   .
    Select reverse gear.
    Adjust the exterior mirror on the front passenger side so that you have a good view of the kerb area.
    The settings for the mirror position will be saved automatically and assigned to the vehicle key that is used to unlock the vehicle.
    Selecting the settings for the front passenger exterior mirror
    Turn the rotary knob for the exterior mirrors to position L.
    With the ignition switched on, select reverse gear.
    The front passenger exterior mirror will move out of the position saved for reversing when the vehicle is driven forwards faster than approximately 15 km/h (9 mph) or when the rotary knob is moved out of position R into another position.
    Sep 2011
    Discovered this weird one tonight - when driving in Eco mode, the cornering lights don't illuminate. They'll only work in Normal, Comfort, Sport or Custom driving modes. Strange. Wouldn't have thought a cornering light would use that much power they'd feel the need to disable them in Eco. Wonder if it can be changed with VCDS?
    Jun 2016
    Surry Hills, NSW
    Quote Originally Posted by sillygogo View Post
    Damn, that's stupidly complicated!
    Jul 2014
    Adelaide, South Australia
    It looks far more complicated than it actually is.
    1. Put car in reverse.
    2. Adjust LH side mirror to where you'd like it
    3. Leave the rotary adjustment know on L.
    That's it.
    Andrew
