Hi,
anyone there with a mk7 R with bi-xenon and halogen rear tail lights?
Long story short... I ended up upgrading my BCM (came from a GTI MK7.5) and retrofit the R bi-xenon practically at the same time and now I have my light channels all over the place, the lights are working (sort off…) and I have few errors in the MFD.
I was hoping to get an admap from a MK7 R with the above light configuration to see if I can guide myself and get the light channels sorted.
Thanks.
Guto.
Golf Wagon MK7 (9092TSI) - Mods: DQ250 swap, 110TSI Turbo upgrade with Stage 2, Bilstein B12, Pretoria 19", GTI PP Sway bars upgrade F/R, Full GTI Tartan interior, GTI colour Cluster, R's Bi-Xenon with AFS retrofit, GTI brake upgrade.
More to come...
BCM/module 9 - Pastebin.com
There you go. Forum won't let me upload the csv file. My VCDS interface is too old to do an actual hex restore file.
Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
VW Wolfsberg Wagon BCM dump - engine off but ignition still on - Pastebin.com
Both of these were done with the requested security code entered.
Thanks so much for the admap, now I have the light channels right (although still having some weird issues) but the headlight is fully functional now.
More to come...
Hi all,
I managed to get the head light working thanks for Ben’s (hardy_bm) help giving me an admap to use as a guide and also check the tail light configuration. I still have some weird issues with the BCM coding and the light channels, if anyone around here with a sharp eye could give me hand, I'll really appreciate.
I do have a couple errors related to the AFS and I still waiting for the parts to finalise the retrofit.
The errors that I’m having are:
Still have errors coming to the MFD regarding the front turn lights (also I have the quick turn blink light in the dash as it had a burn bulb somewhere) and the dipped beams
The module was originated from a GTI MK7.5 2 doors and I changed the ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer (from 2 to 4 doors) and the rear driver’s doors sometimes doesn’t lock, also, the two rear windows don’t go down anymore when I open them through the key.
The footwell light control in the MIB is not there.
Any help is welcome!
Thanks,
Guto.
Log and admap here:https://drive.google.com/drive/folders/1BsQVDgc6RbTlTYTdcVWDRL0wp5L_uRb4?usp=sharing and here https://drive.google.com/file/d/1Pp7...ew?usp=sharing
More to come...
