Not quite. Needs a new USB Plug/Screen (8 inches in my case) /surround and Glovebox unit and have to modify some of the plugs (which is not hard to do) . Also if you want DAB you need to fit an Antenna if you have no idea how to do this stuff can be a bit tricky and in your case if no original GPS module you will need to an antenna for that as well. They are not cheap either. I have a MIB 2 With Carplay & DAB in mine great radio if you can afford it is worth while. There are other options though Alpine make a unit and you can by a a unit that will just give you a MAP option like Volkswagen MK7 Golf - GTI - R - 8" Golf7 Multimedia Navigation System.
