Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: MY19 GTI headlight query
    Mar 2019
    Have the MY19 GTI with the Luxury and Sound/Vision Pack. Can confirm that you get dynamic cornering lights and also at low speed an extra light comes on in the direction in which you indicate/turn (whichever action comes first) at low speed which is a nice touch.
    Also noticed that you only get the single bar DRL on each side with the MY19 which is different to the MY18 which is a little odd. It looks like the LED's are there so maybe this is just a simple VCDS/OBDELEVEN coding?
    Does anyone know?
    Nov 2017
    Coffs Harbour NSW
    Quote Originally Posted by Ozsko View Post
    Are your lights LED?
    Yes. LED headlights.
    2018 Golf GTI DSG (DAP LUX INFO R-TAILS)
    Dec 2010
    Helensburgh
    Quote Originally Posted by crainger View Post
    Not sure if I can help, but I have a MY18 GTI with DAP, it has lights that turn with the wheel, the corner light that comes on as you turn at low speeds, high beam assist and has twin DRL. My understanding the MY19 comes with DAP standard now.
    The problem is DLA means different things to different people. DLA to me means headlight beam shaping to prevent glare to other road users and not cornering lights.
    ^^^^ Do you own, or do you have access to a diagnostic cable -something like VCDS, OBDeleven, or similar?
    I'm not entirely sure about DLA. but in general- If so, check the setting for the adaptation channel static AFS light-Vorschrift which lives in the BCM (the control module @ address hex09). "AFS" is VW's acronym for "Adaptive Frontlighting System" and it refers to the operation of the "Cornering light CAN bus". "Vorschrif" is German for "Regulation". So, this channel determines what set of road rules (if any) the car will use to manage the cornering light function. If the value of this channel is ECE R119 then more than likely, your car does have an active AFS facility.
