Originally Posted by
f080361
Hi guys,
I know this issue has been raised a couple times before on other forums as well, but I get a beeping? sort of noise from the engine bay once the car is ignition off and unlocked.
I've done some searches and its a common thing that occurs - but my car was still making the noise after a good nights sleep!?
I've only just taken delivery of this vehicle which was a dealer demo (3000kms).
I've attached a short clip where you can faintly hear the noise. It beeps for a good 5 sec then pauses - then starts again.
Is this normal for it to beep after 10 hours of parked / locked?
f080361: Difficult to say - from the recording. If the noise appears after you have driven home and turned the ignition-off, then it could be the electric pump for the turbo coolant - this normally runs fro a few minutes after switch-off until the coolant thermostat tells the pump to shut-down . If the noise appears in the mornings after you unlock the car and open one of the doors, then it is probably the fuel tank pressurising pump - which engages in anticipation of an engine switch-on. Both -just guesses!
