Before I go any further with this, I want to rule out the way that I'm measuring the time. I was using a stopwatch first, and then the car's in-built lap timer using the hand controls, both of which are very far from scientific.
With that in mind, I took some videos tonight and uploaded them to YouTube for you all to look at.
I measured the times frame by frame, using my video editing software. The question is, when do you START measuring the time? From first tacho movement, or first speedo movement (speedos have a lot of slop)? I figured I would post times from both methods:
Run 1 -
YouTube - tach:
6.99 s ; speedo:
6.15 s
Run 2 -
YouTube- tach:
7.02 s ; speedo:
6.86 s
Run 3 -
YouTube- tach:
7.02 ; speedo:
6.85 s
Hmmm, I guess the times aren't as bad as I thought, and traction does still seem to be a factor given the 6.15 s result on the first run.
I think I might be an insane person looking for problems. I'll let you guys be the judge and jury
