Nice and clean again
The plan would be to use the Cupra copper colour. But was quoted $264/wheel to repaint the centre
2024 CUPRA Leon V Tribe Edition
Couple of small changes to the rear. Swapped to gloss black rear spars and deleted the diffuser add-on. I much prefer the cleaner oem look
Replaced to old battery today. Was definitely past it’s used by date, the positive terminal was cover so badly in corrosion . I don’t think it was even the correct battery in the first place and wasn’t coded to the car either. All sorted now
Also my new co pilot
Just pour some baking soda over a terminal like that and will clean it off
That battery is fine for the Golf Mk7 - I run exactly the same Century DIN65LH AGM model in my MY18 Passat. The battery hold-down clamp and battery tray have different bolt holes to suit different size batteries for different applications.
Sounds like the battery is dead though, that's for sure.
