Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 55
Thread: my first venture in to the mk7 club...
  1. #41
    brisbane
    Quote Originally Posted by gregozedobe View Post
    I've read that is easier with the engine warm (but be careful not to burn yourself). IIRC there is a special tool for pulling the coils off the spark plugs.
    Yes the oil changes are nice and eay - no need to remove oil pan cover etc. I never fully trusted the weird sump bolt....but it never leaked (always used a new one).
    As for the ignition coils, yes they are a pain to remove but as mentioned above, its easier if the engine is still warm.
    thanks for the feedback. the engine was still warm from the oil change and the plug puller tool is just to the right of the spark plugs in the photo...
    I didn't really need the tool as the top of the coil came away from the valve cover easy enough. it was the rubber boot that felt welded to the spark plug ceramic way down the hole. it literally stretched about 50mm before it let go, I thought I was going to rip the boot...
    I think its maybe caused by years of heat cycles and eventually welds on. I did spray some lubricant inside the rubber boots to try and prevent it happening in future but I guess it will evaporate over time...
    I used a new sump plug from VAG and also bought the removal tool as I hadn't used one of those plugs before and wasn't sure how it worked. an Allen key of screwdriver would have probably been just as good...
  2. #42
    Sep 2016
    Quote Originally Posted by guile View Post
    as per usual I said I wasn't going to modify this one for performance as its meant to be a cheap comfortable daily driver to cart the dog around and lend to visitors when they stay...
    but my parents complained about lack of induction noise and throttle response when they were over last time so I bought this lot in order to help...
    I decided to test the cheaper options out there as I don’t expect the car to get much abuse and it’s a bit of a test to see if the fitment is any good or complete garbage. I’ll report back once fitted…
    How are you finding the intake? Ebay units seem to go for under $100 whilst a name brand is $300.... Is the quality OK?
    Sent from my SM-G998B using Tapatalk
  3. #43
    brisbane
    hi mate, I think the quality is awesome for the price and wouldn't hesitate to buy again for a daily driver...
    I'll report back if anything wears prematurely and take some photos next time I've got the bonnet open...
  4. #44
    brisbane
    I’ve decided to try and do an active cruise control retrofit as its one of the modern car features I actually like in a daily car and will make freeway driving up and down the coast much easier…
    As I’ve been doing budget upgrades to this car I decided to try sticking with that theme, hopefully it won’t be a tale of buy cheap buy twice…
    Apparently my car needs to be equipped with Gateway High and Extended Can which I really should have checked before starting to buy parts…
    These are the parts I need as far as I’m aware…
    - Front bumper centre grille with radar hole – 5G0853677D
    Purchased from ebay for $80
    - ACC radar plug – 4F0972708
    I won’t be needing this as I bought a loom including the plug from ebay for $40
    - MFSW steering wheel switches – 5G0959442N
    Purchased from ebay for $200
    - Bosch Long Range Radar (LRR) – 5Q0907541D, F, G, H, J, or P
    Purchased from a wreckers for $500
    - Rear bidirectional ABS sensors – WHT003864A
    Need to check if my car already has these fitted
    - Component Protection Removal
    Currently trying to find a place in Brisbane that can offer this service
  5. #45
    May 2020
    Canberra
    An impressive undertaking!
    I look forward to seeing how it goes.
    MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
    MY19 AW Polo - Comfortline - DAP
  6. #46
    brisbane
    Quote Originally Posted by genebaby View Post
    thanks mate, was a bit daunting but I'm just trying to break it down to manageable parts...
  7. #47
    brisbane
    some of the parts have arrived, first up the bracket. it's missing the levelling screw etc but I suspect I might end up with another when I buy a radar anyway. I just wanted this to use as a template to drill the crash bar...
    next was the wiring harness which I'm very impressed with for $40. it comes with all the loom tape and split conduit...
    it also comes with a splitter for connection to the can bus so I can de-pin the existing then plug in to the splitter plug...
    steering wheel switches, not cheap. hard to get hold of in the correct part number, I ended up getting these from the UK...
    radar, also not cheap but feel like I got this at a good price and from Australia so not suffered the bad weather...
    as suspected it came with the bracket and face cover which is good. I might try and cut the other bracket down and use that as the face plate between the bumper and radar bracket...
    its a revision J which I haven't read much about however I'm reliably informed it supersedes revision G so lets hope it works...
    looks like it has the correct number of pins which is a good start...
  8. #48
    brisbane
    my plan for the first stage is to get what I think is the hard part out of the way. drill and fit the radar mount and new grill surround then run the wiring harness from the mount to inside the car via a grommet behind the battery. this will bring the harness in to the cabin near the glovebox and access to the can bus wires at the tiul connector...
    the wiring should be pretty easy and I'm fairly confident the below wiring diagram and colour coding is correct. I'll use a fuse tap for the red power wire and a decent ground on the body for the black wire...
    tiul wire colour coding on the left to the radar harness pin out on the right:
    Or/Gr -> CAN-Bus Extended High -> Pin 2 on Radar
    Or/Br -> CAN-Bus Extended Low -> Pin 3 on Radar
    next up is the fitting of the steering wheel controls, radar and completing the coding including component protection removal...
  9. #49
    Mornington Peninsula, VIC
    Nice work, the ACC is 100% worth it
    With the LRR do you get any benefit to running the second can line to the lane assist camera? I know on the MRR you only get 160 Km/h and 210Km/h with the camera in fusion mode. (not that it really matters here, no autobahn )
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
  10. #50
    May 2020
    Canberra
    Yes, I love having ACC. Good work.
