from posting in the coding forum and reaching advice from Don, I think I've got the coding sorted...
19 – Gateway
Add 13 – Auto Dist. Reg on the installation list
Under Adaptation change steering wheel type to ACC
01 – Engine
Set ACC with Front Assist ( PR-8T3, PR-8T8 )
03 – ABS
Edit Byte 24: Change to F8
Edit Byte 26: Change Bit 2=1 and Bit 4=1
17 – Instrument
On the cluster set all the ticks for Front Assist and Distance Regulation
5F – Radio
Set all the ticks for Front Assist, ACC and PreCrash
13 – Radar
Set presence of ACC
I'm going to have a crack at fitting it this weekend but still waiting on the steering wheel switches coming from the UK...
In the meantime I'm going to research ODIS to see if I think its worth buying and removing CP myself. Otherwise the stealer has quoted $180hr diagnostic time and you'd hope they'd be able to do the CP removal in that time frame...
