Daytime Running Lights- turn off/on via media screen
Daytime Running Lights - turn off/on via handbrake
Daytime Running Lights - remain ON when turn signal "blinks"
Daytime Running Lights - dim when turn signal "blinks" (thanks bobcrusader)
Daytime Running Lights - acknowledgement flash with lock/unlock (OBD11)
LED Number Plate
Coming Home Lights
"Blinkers" - change cycles
Fog Lights - Combine with High Beam Lights
Incandescent Tail Lights - add Brake function to inner lights
LED Tail Lights - add Brake function to inner lights
LED Tail Lights - add "Pace-Car" indicators
Halogen Headlights - add Counter blinking DRLs on turn signal (instead of "DRL Wink")
"Angel Eye" Headlight fittings- Illuminate Dot with switch in all positions (thanks MRG_AU)
"Angel Eye" Headlight fittings- DRL Wink (thanks MRG_AU)
Single Sided Parking Lights (SSPL)- Enable SSPLs (thanks dmc_)
3rd Brake Light - Various Tweaks (thanks Morde)
Outer Tail lights- illuminate when hatch opened (thanks harisg)
DV52-Tails (for incandescent taillight assemblies)
Low-beam + Parking lights (for incandescent taillight assemblies)
Footwell Lighting enhancement - Hearing impaired aid for turn signals
Rear Turn Signal lamps - Pace Car operation with Hazard warning lights (LED tails)
DRL - Coming Home/Leaving Home (without Low-beam lamps)
Rear fog light - operate with High-beam "flash"
interior lights - gradually illuminate on/off (thanks Fashionci)
