I'm confused. One of your front rotor is worn down to less than a fingernail thick? Did you mean pad?
If it's the rotor, you have bigger issues. Their spec for replacement is usually 2mm of wear measured, which leaves plenty of material.
Check if your pads need replacing too. Do everything as a pair.
You will need a piston pusher to put the new pads in. You will also need VCDS to change the back pads as you will need to put them into maintenance mode.
Have a syringe ready to suck some brake fluid out of the master cylinder as you push the pistons back. Usually you are ok, but some mechanics top up the fluid during services as the pads are worn.
This creates a mess when you push the pistons back and all the fluid overflows the tank. Brake fluids are highly corrosive so you don't want that
The rotor size should be in your owners manual. Try to get rotors for European cars if you go aftermarket
and get the best (non-performance) pads you can afford.
After all, the only things that will prevent a crash are your 4 tyres and brakes
