Results 1 to 4 of 4
Thread: MK7 TSI Clutch Error
    Jan 2018
    Hi guys, I've got this clutch error on my golf mk7 tsi. The car drives fine for the moment but wondering what the likely fix is for this? I'm assuming i'll need to replace the clutch in which case does anyone have a ballpark on how much it will cost?
    If it's an expensive fix is it something that I can buy used at a wreckers or something and get replaced at a shop or is it not much more expensive just to get it done at a dealer. Times are tough at the moment so just trying to get a good enough fix that will last me another 50,000 or so km's.
    MK7 TSI Clutch Error-349187009_988839755620859_4711334074358974459_n-jpg
    Hi and welcome. It sounds like your clutches are worn out and will need replacing. While the car is still driving ok id be getting it booked into one of the many VW specialist workshops in the Sydney area to be correctly diagnosed and new parts ordered, otherwise if you leave it you risk damaging other parts and or having the car break down (which could be dangerous) and then you need to tow it.
    Jan 2018
    Thanks for the response, I've got a quote from a few places. Weird that all the places quoted at the same level or more as the dealer. I should just go to the dealer then if that's the case?
    Jan 2018
    FYI to anyone who runs into this, after contacting a bunch of mechanics VW are actually the cheapest to fix it. Shop around as it differs between dealers but cheapest I got it for was 3300.
