@onejay: :Hi and thanks for the PM
Yes, Australian early model mk7s that were factory built with halogen headlights were coded so that the DRL lamps did NOT illuminate with low-beam lights. Instead, the driver needed to select the
position (i.e. Parking Lights) on the rotary-light-switch to turn-ON these lamps after dark
Some models in other countries didn't have this limitation - I have no idea why Aussie cars were so coded!
Anyhow, way back in August 2016 - I wrote an instruction-set to change this behavior, which you can read HERE.
My original purpose for the tweak was for use with the OEM halogen lamps, so I kept the illumination level during low-beam operation at the factory value. I'm not sure how this light intensity will suit the new Supernova lamps - but if you want to change, modify the setting on Dimmwert EF on both Leuchte-sets. However, don't be too heavy-handed (please) because high illumination has a tendency to blind drivers in on-coming cars
