Page 11 of 21 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 204
Thread: Mk7 iPod Compatibility (MDI, Bluetooth etc)
  1. #101
    May 2010
    Quote Originally Posted by adhock View Post
    My experience after 10 days in a mk7 high line:
    1. There is no MDI plug or anything like what was in my mk6. Nothing. End of discussion. No way to connect MDI in an Aus spec mk7.
    2. USB is charge only. It will not recognise an iPod Classic, period.
    Correct it won't recognise an ipod - I was also expecting it to. However it will recognise a USB thumb drive with music and works just like the sd card. I often encountered instability with my previous mdi/ ipod setup so I'm in favour of using just a USB or sd card. As you say cheaper than a dedicated ipod.
    Current: Mk7 GTI, DSG, White, Leather, Driver assist, Sunroof, Xenons
    Previous: MY10 Golf 118 tsi, Candy White, Sports Pack, Corn Leather, MDI.
  2. #102
    Mar 2014
    Hi all, I started a thread a couple of days ago regarding the BMW Ipod Y cable and was going to discuss my success (or lack of) with it but now the post is closed and I can't get into it. Why is that?
    Anyway, I will explain how I went in this post. I am picking up my new Golf 103TSI Highline tomorrow and I went to VW Camberwell to try out my Ipod Classic 160GB with the BMW Y cable (see below pic) and it worked perfectly except for one thing; you have to select your music off the Ipod itself. The song selections do not come up on the screen menu. My Ipod has all my music in Apple lossless so I get CD quality coming through and yes it will be a pain not being able to select my music on the go through the multi-media controls but it's better than nothing.
    So if you want to be able to play your Ipod (regardless of type) then buy the BMW Ipod Y cable as that connects from the Ipod and splits in to a USB cable for powering and a 3.5mm Audio out cable in a neat small cable which allows you to store it in the cubby hole behind the gear stick.
    What I'm going to do is create a bunch of playlists to suit my moods so I can select a playlist when I get in the car and don't have to worry about changing from one artist or album to another on the go. I hope this helps anyone who wants to connect their Ipod or Iphone to the stereo to play music whilst keeping their Ipod/Iphone charged.
    Steve
  3. #103
    Aug 2011
    Quote Originally Posted by steve2209 View Post
    Steve
    Just a normal retractable 3.5mm aux cable would have the same effect, just without charging is all.
  4. #104
    Mar 2014
    Northern Beaches, NSW
    Quote Originally Posted by golfi_vend View Post
    Hey mate. This is really interesting. I am wondering whether part no. 15, I.e. The cable connecting the interface to the media unit in the glovebox, is the same for The USB/Aux (no. 2) and the Media In interface (no.1). If it is then, without much fiddling, one could swap between them?
    - MkVII 90TSI Comfortline 5-door, 2014, Pacific Blue (LA5J) 6MT, w/ Driver Assist 2 and Discover Media - DELIVERED
    - MkV GTi 5-door, 2009, Candy White (LB9A) DSG, Sunroof, RCD 510, MDI - SOLD
    - MkIV TDi Van, 2002, Reflex Silver (LA7W) 5MT - STILL GOING
    - MkIII 1.4CL 5-door, 1993, Steel Blue (LB5T) 5MT w/ Power steering - BEING REVIVED
  5. #105
    Mar 2014
    Yes you are correct there. But if you want charging as well you'll need the cable above. But I cannot express how disappointed I am that VW can't incorporate the song selections on to the screen. Many other manufacturers have it.
  6. #106
    Mar 2014
    Hi Steve. I understand your disapointment but I must disagree with you. You, in fact do not need the particular Y-cable. You can use your standard Apple USB to iPod cable to charge it and a separate 3.5mm mini-jack cable for the audio connection. There is no need for the Y cable from BMW or any other manufacturer.
    Without knowing first hand, I suspect VW Australia chose to offer the USB/Aux-In interface instead of the Media-In for a number of reasons. I had a Media In interface some years ago in a Golf Mk5. Apart from needing a separate cable for each of your devices (iPod, USB etc), the cables were expensive and especially the Apple cable did not work with all devices properly (i.e. for me it did work with an iPod Classic but not my iPhone 3GS or 4). If you look at European fora at the moment, you will find that people are also having compatibility problems with the Mk7 Media-In interface and especially with the iPhone 5 and 5S needing newer versions of the cable etc. I know from first hand experience that BMW experienced similar problems with their USB interface in the E90 series when the iPhone 5 came out.
    Also you need to remember that a lot of people don't have iPhones or iPods and for them the easiest way to connect a device is a (very cheap and ubiquitous) 3.5mm cable. Yes, you lose the ability to control the device on the touchscreen of the car but if that's really important to you then you can have that using an SD card instead. The SD card will also work faster. That way you also have the USB port free to charge your mobile phone and also take advantage of the inductive phone aerial that works in the little cubby in front of the gearshift knob. Failing that I'm sure that in a few months we will see someone will have swapped the USB/AuxIn interface with the Media In with not a lot of difficulty.
  7. #107
    Aug 2011
    The Y-cable is a much neater solution though, and its good to know if works for people wanting something more streamlined.
    Don't forget that if your ipod has bluetooth you can connect it up for titles and play/pause/prev/next
  8. #108
    Apr 2013
    Can you put playlists on the SD card? .m3u files or whatever they are?
  9. #109
    Mar 2014
    Quote Originally Posted by stedes View Post
    Thanks stedes. I'm coming from the perspective of a current BMW X3 with the premium sound package so I was expecting something similar. I'll play around with the SD card option when I pick the car up but I don't like the smaller capacity of the cards as I don't play compressed music so I need the space. I guess you can't have everything.
  10. #110
    May 2010
    Quote Originally Posted by Jimi View Post
    From what I can tell so far the system doesn't know what to do with any file that's not a music file. So m3u is a no. I've grouped songs into folders as a workaround
