Results 1 to 4 of 4
Thread: MK7 GTI PP MY14 - Water pump and Fuel pump replacement needed
    Hello Good people ,
    I have an Issue right now where there are minor leaks (couple drops every other or 4th day) on Both fuel and water pump . Car went into service at reputable indy Service shop and they sent a quote yesterday . It came to about $3100 (approx) , would like to know experience of others and does the quoted price seems genuine . They will be using OEM< parts is there a recommendation to use after market better parts for longevity . I intend to give the car to my daughter next year as wife will likely to update hers .
    Now before the Comments begin :
    I am not concerned about the Price but i am a person who works hard for his money. I like to check with collative hive mind .Money is not an issue , want to confirm that i am paying the Right price and not getting ripped off.
    I appreciate your time and valuable advise
    Water pump/thermostat parts are about $630. And around $600-700 for labour as its not a fun job. Water Pump & Thermostat Housing Bundle (MQB) EA888 Gen 3 - 2.0 TFSI EA888.3 – VAGPARTS Australia
    Best off to stick to VW genuine parts for the water pump as they have revised it a few times to try and make it better. Hopefully an aftermarket company will make a cast aluminium version soon - but none are available yet.
    The high pressure fuel pump which is bolted to the head of the engine (and is run off the inlet camshaft) is $580. You could easily replace this yourself with some basic tools if you are mechanically minded. Otherwise I cant imaging you would be charged more that 1hr labour ($150 ish) to replace it - its a pretty simple and quick task. 06J127025L - High Pressure Fuel Pump - Audi & Volkswagen 2.0 EA888 – VAGPARTS Australia
    One thing to check with the fuel pump, are you sure its not just a perished o-ring that is causing the leak? Is it leaking oil or fuel?WHT005184 - O-Ring for Fuel Pump EA113 – VAGPARTS Australia
    So $3,100 does sound a bit rich. I would think $2,000-2,200 would be a more realistic price for both items to be replaced.
    Thank you for links and info , Sorry i probably can do it but i am very time poor due to work and other duties .
    Fuel Pump is leaking oil . I would have trusted the shop as it has very good repo here in SA but now i will shop around and check first . perhaps i can provide my own part since they re charging almost double in comparison.
    Quote Originally Posted by MRsnipeit View Post
    If the fuel pump is leaking oil then its almost certainly just the o-ring. Certainly worth a try for $20.
