Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 68
Thread: Mk7 GTI officially revealed
  1. #41
    Jan 2012
    Epping, NSW
    when I saw that I thought great handbrake, I forgot it had an e brake!, would that make doing this impossible? must have been modded with a normal cable brake.
  2. #42
    Apr 2010
    Maybe there is a VCDS setting to enable the e-Brake at speed???
  3. #43
    The rear wheels look like they are spinning even when the rear moves out.
    There is more than one way to make the rear come out on a car than using the handbrake.
    By definition an "e-brake" (how very american - "e" for emergency) has to be able to pull up a moving vehicle. So, you must be able to activate the electric handbrake in a the new golf whilst it is motion.
  4. #44
    Apr 2010
    Yeah "e" could now mean emergency or electronic...
    Fifth Gear did an auto-test using the latest hot hatches and they said the Astra VXR had an electronic parking brake that wouldn't be used unless the car was stationary.
  5. #45
    For the GM Volt (and i assume most GM cars - Opel etc)
    The EPB can be applied anytime the vehicle is stopped. The EPB is applied by momentarily lifting up on the P switch. Once fully applied, the Electric Parking Brake Light will be on. While the brake is being applied, the Electric Parking Brake Light will flash until full apply is reached. If the light does not come on, or remains flashing, have the vehicle serviced. Do not drive the vehicle if the Electric Parking Brake Light is flashing. See your dealer.
    If the EPB is applied while the vehicle is in motion, a chime will sound, and the DIC message RELEASE PARKING BRAKE will be displayed. The vehicle will decelerate as long as the switch is held in the up position.
    Releasing the switch during the deceleration will release the parking brake. If the P switch is held in the up position until the vehicle comes to a stop, the EPB will remain applied.
  6. #46
    May 2011
    I've read conflicting articles on which DSG is in the new Golf. Is it a carry over from the MKVI (DQ200 etc) or a whole new box?
    One article said that the only thing they've carried over into the new model is the gearbox, which with all the horror stories of that DSG, you'd think they wouldn't!!!
    Polo GTI - 5 door - Candy White, Xenons, Comfort Package, Audio Upgrade, Bluetooth, Parking Sensors and Tint
  7. #47
    Apr 2010
    Maybe they just say the same in terms of '7 speed DSG' and not in terms of DQxxx ?
  8. #48
    Oct 2010
    Perth
    Nov 2009
    Quote Originally Posted by prcurrie View Post
    It uses the existing 6-speed. VW haven't developed an all-new 6-speed DSG as of yet. It's likely there are ongoing refinements (and running changes) however - certainly on the software front.
    The existing 7-speed also carries over in the lower models.
  10. #50
    Feb 2010
    17" -v- 19" Wheels
    Haven't seen what the 18" wheels look like, but I imagine they would look like the 17" version, only taller. 19" wheel spokes look like tuning forks:
    First MK7 GTI and GTD pics from 2013 Geneva Show Debut - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
    Side by side profiles further down in the pic sequence.
    Cheers.
    WJ
