Mk7 gti coolant leak after radiator replacement
Hi guys,
My 2014 GTI performance pack had a coolant leak, spotted on the right side of the engine bay's splash shield, which turned out to be from the radiator. Post-radiator replacement, the coolant level continued to drop, but I found no leaks on the earlier spot, so I assumed it was the new radiator settling in.
I decided to check again now after a few weeks, I noticed coolant now on the left side of the engine bay's splash shield near the engine, this was not here before, I’m not sure where it is coming from, I've attached some photos.
Maybe it’s a loose hose or something from the radiator replacement?
Any insights would be greatly appreciated. Thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
