Originally Posted by
Kesh
I have a 2014 Base Mk7 Golf 90tsi DSG, I don't have the mirror dipping function. I believe it can be enabled through vids. Just trying to find someone who can help me enable it now.
Kesh: don't get me wrong, I reckon that VCDS is a fantastic tool, but it doesn't perform miracles! You are referring to the coding changes that can be made to the passenger side door module for enabling mirror dip. I'm not sure which module is in a 90TSI, but even assuming that Ross-tech's software will enable access to the appropriate Byte/Bit in the module controller, the problem will then be in the down stream equipment. Does the passenger side mirror in a 90 TSI have a memory module? I don't know the answer, but without it, how does the left hand mirror know where to point in the dipping process?
This said, I do recall reading a post on a foreign website somewhere (long ago) where the author claimed that it was possible to reverse-dip a mirror without a memory module, but only to a preset position (i.e. It was not adjustable). If you find somone in NSW who is willing to do the tweak, please let us all know the outcome ( PM if you want the tweak instructions)
