Page 73 of 109 FirstFirst ... 2363717273747583 ... LastLast
Results 721 to 730 of 1081
Thread: Mk7 Golf TSI & TDI - Observations and Questions
  1. #721
    Enable Traffic Information (TMC) on Mk7 Golf - VCDS tweak
    Step 1. On "Select Control Module" option click "Select"
    Attachment 8318
    Step 2. Select "5F-information Elect"
    Attachment 8319
    Step 3. Select "Adaptation"
    Attachment 8320
    Step 4. Using pull-down menu, select "Fee Based Traffic Information (TMC)" channel (it's about 20% down the channel list)
    Step 5 Change default value "0" to ?????
    Edit (30/04/2015): The magic number for Step 5 is apparently "1024".
    This value was initially suggested in sucnip's post below (see #55)
    And the value was confirmed in alanzidan's post below (see #48 - tweak 5.1)
    The remaining steps in the procedure are:
    Attachment 9241
    Step 5. Enter "1024" into "New Value" box and click "Do It!" tab.
    Attachment 9606
    Step 6. Click the "Yes" tab in the "Re-code Invalid" screen.
    Step 7. When the screen in Step 5 returns, click "Add to log" to record a copy of the change report.
    Step 8. Click "Go Back" (in Step 5 screen) and exit the VCDS software
    Missing Adaptation channel - Fix
    The channel, Fee Based Traffic Information (TMC) in step (4) appears in the drop-down list if byte 13 of 5F-information Elect. controller has a coding value of hex09. If this channel does not appear, then byte 13 may need to be changed to this vaue (thanks zloybob.)
    Please note the following after the tweak has been completed:
    1. For TMC to work, "TP" and "RDS" need to be activated in the set-up menu for the radio
    2. It may take some time for the new facility to be established and for the initial set of traffic reports to be downloaded. In my case, the wait time was over an hour, but others have reported longer times.
    Anyone know if this procedure can be carried out in a mk6?
    MK6 CS GTI
  2. #722
    Nov 2009
    Quote Originally Posted by kash_0 View Post
    The Mk6 uses an entirely different head unit and traffic information system. See existing threads in the VW Car Audio and Electronics forum for details.
  3. #723
    Oct 2010
    Thanks for your replies. Appreciate your comments and assistance. Sorry for not acknowledging it earlier. Some things I'll just have to get used to. Otherwise its a fantastic car and I'm enjoying the experience.
    Golf 2013 Highline 110 TDI White Driver Assist
    Previously-Golf 2010 Comfortline Silver TDI DSG
    Previously VW 1970 Beetle
    Previously VW 1969 Type 3 Squareback
  4. #724
    Feb 2010
    Sydney,NSW
    Anyone know if the MY 2015 Golf 7 2.0 tdi is running the new EA288 euro 6 engine
  5. #725
    Apr 2011
    Quote Originally Posted by Zeke View Post
    Are you sure you're not getting confused with the US people getting the EA288 that we already have? (Or am I getting confused to?)
    Edit: Ah, yes, I've only got the Euro 5 EA288...
    The current volkswagen-golf-brochure-my15-web.pdf file from the Australian website still only says Euro 5, but VW have been known to make stuff-ups with printing brochures with incorrect information. (Voice control, LEDs on plates with Xenons...etc)
  6. #726
    Feb 2010
    Sydney,NSW
    I'm beginning to think that it's the same engine that's already in place in Oz.VWA just hasn't updated its Euro 6 compliance or made a typo
  7. #727
    Erskineville, NSW
    Maybe the Euro6 compliance doesn't work because our diesel isn't good enough? Just guessing
  8. #728
    Apr 2011
    Euro 5 vs 6 is:
    NOx drops from 0.180 to 0.08
    HC+NOx drops from 0.23 to 0.17
    Everything else is the same. (This is for Diesel)
    The main challenge is the nitrous oxide:
    "To meet them, car manufacturers are having to invest in yet more new diesel engine filtration technology to clean up exhaust emissions. One example of this is Selective Catalytic Reduction, which stores emissions and then ‘selectively’ heats up to regenerate and neutralise the emissions. Another alternative is a fuel-borne urea solution (commonly known as ‘AdBlue’) which breaks down emissions in the exhaust."
    Interesting.
  9. #729
    Oct 2014
    Doncaster
    Is the Nigh Blue Met Paint no longer available? I tried to search on official web and
    Is the Night Blue Met Paint no longer available? I tried to search on official web and it disappear...then i download the brochure which also excluded the night blue paint, it's a big reason why I'm considering the golf 7.....
    On the other hand are there any
    identified difference between My14 and MY15? I don't understanding why it should be more expensive?
  10. #730
    Nov 2009
    Quote Originally Posted by chesterin9 View Post
    On the other hand are there any [/FONT][/COLOR]identified difference between My14 and MY15? I don't understanding why it should be more expensive?
    See here:
    MY15 Changes - Mk7 Golf
    And specifically:
    • The exterior colour Night Blue Metallic Z2Z2 has been discontinued (excludes GTI & GTI Performance)
