Page 56 of 109 FirstFirst ... 646545556575866106 ... LastLast
Results 551 to 560 of 1081
Thread: Mk7 Golf TSI & TDI - Observations and Questions
  1. #551
    Nov 2009
    SEQLD
    That is poor! I was lucky enough to get mine installed yesterday
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
  2. #552
    Dec 2007
    ivanhoe vic
    That is crap I wouldn't be accepting that
    B6 Passat Wagon No KESSY
  3. #553
    Nov 2009
    SEQLD
    If you order the bi xenons before this alleged bulletin, it would have to be against Australian consumer law. ACCC or Qld OFT should help.
    MY20 Golf GTI TCR
  4. #554
    May 2010
    Quote Originally Posted by Brendan_A View Post
    I agree. I'm not going to leave it there
    Current: Mk7 GTI, DSG, White, Leather, Driver assist, Sunroof, Xenons
    Previous: MY10 Golf 118 tsi, Candy White, Sports Pack, Corn Leather, MDI.
  5. #555
    Dec 2007
    ivanhoe vic
    Don't they have some kind of disclaimer against the brochure still you could argue product you received is not what was advertised
  6. #556
    Dec 2013
    Altona, Victoria
    Quote Originally Posted by ihawk View Post
    Just had a call from my dealer who told me VW has issued a bulletin advising they printed incorrect information in the brochure. So they won't honour led license plate lights - they just shrug and inform us the brochure was incorrectly printed. Poor form VW
    I actually went into my dealer today to ask the question and I was informed and shown the bulletin to. Lucky for me they have agreed to honour the brochure and install the LED tail registration light =). Car's booked in for next week!
    MK7 MY14 Golf 103 TSI Highline | Pure White | DSG | Anti Theft | Sunroof | Bi Xenon | Driver Assist | Leather | 18' Motorsport wheels
  7. #557
    Enable" Traffic" button on Mk7 Golf - VCDS tweak
    Enable Traffic Information (TMC) on Mk7 Golf - VCDS tweak
    Step 1. On "Select Control Module" option click "Select"
    Step 2. Select "5F-information Elect"
    Step 3. Select "Adaptation"
    Step 4. Using pull-down menu, select "Fee Based Traffic Information (TMC)" channel (it's about 20% down the channel list)
    Step 5 Change default value "0" to ?????
    Edit (30/04/2015): The magic number for Step 5 is apparently "1024".
    This value was initially suggested in sucnip's post below (see #55)
    And the value was confirmed in alanzidan's post below (see #48 - tweak 5.1)
    The remaining steps in the procedure are:
    Step 5. Enter "1024" into "New Value" box and click "Do It!" tab. (edit: I have seen the code "32771" used in UK models in this adaptation channel)
    Step 6. Click the "Yes" tab in the "Re-code Invalid" screen.
    Step 7. When the screen in Step 5 returns, click "Add to log" to record a copy of the change report.
    Step 8. Click "Go Back" (in Step 5 screen) and exit the VCDS software
    Missing Adaptation channel - Fix
    The channel, Fee Based Traffic Information (TMC) in step (4) appears in the drop-down list if byte 13 of 5F-information Elect. controller has a coding value of hex09. If this channel does not appear, then byte 13 may need to be changed to this value. Byte 13, bit 3 needs to be set for RDS to be enabled as per the screen-shot below (thanks zloybob.):
    Finally, after the changes above have been made, it's a good idea (I think) to reset the infotainment unit as follows: Press the on/off button on the radio until the unit switches off and keep holding down the button until the unit switches on again
    Please note the following after the tweak has been completed:
    1. For TMC to work, "TP" and "RDS" need to be activated in the set-up menu for the radio
    2. It may take some time for the new facility to be established and for the initial set of traffic reports to be downloaded. In my case, the wait time was over an hour, but others have reported longer times.
    EDIT: Further information from zloybob -
    Quote Originally Posted by zloybob View Post
    hello Maybe i can help u with TMC
    1024, 65535 etc its value for various settings (This can be seen in the firmware file)
    65535 - TMC OFF
    1024 -
    SUNA Traffic (Intelematics)
    0 - dev options
    32771 online traffic + VW TMCPro
    this is true for MIB1... but this could change for MIB2
    Attached Thumbnails Attached Thumbnails Mk7 Golf TSI & TDI - Observations and Questions-tmc_2-png   Mk7 Golf TSI & TDI - Observations and Questions-tmc-screen-5-png
    Mk7 Golf TSI & TDI - Observations and Questions-screen-2-png   Mk7 Golf TSI & TDI - Observations and Questions-screen-3-png
    Mk7 Golf TSI & TDI - Observations and Questions-screen-4-png
  8. #558
    Nov 2013
    AUS
    DV52, I respect your determination, I've been stockpiling VCDS tweaks so I can get them all done in one go. I hope Gekozao's mate can help us all out!
  9. #559
    Quote Originally Posted by veew View Post
    veew: I suspect that my determination and your respect might be misplaced- but thanks for the sentiments anyway. My fledgling attempts to understand how VCDS integrates into the MQB platform has proven to be very tedious and very tenuous!
    In the end, I'm convinced that any meaningful advancement in our collective understanding of Mr Ross's equipment and the mk7 can only happen as a collaborative exercise. Hence the benefit of forums like these and hence my request to GekoZAO and his/her friend!
  10. #560
    Jun 2008
    Sydney Inner West
    Another example of VGA advertising something them deciding they don't need to provide it (Voice command?) because they can claim an error in the brochure - either their printers or their marketing department are extremely incompetent or they just couldn't care less.
    How soon before they finally say - "you don't actually get a car, just a big box of spare parts, it was a mistake in the brochure"
