Page 82 of 109 FirstFirst ... 3272808182838492 ... LastLast
Results 811 to 820 of 1081
Thread: Mk7 Golf TSI & TDI - Observations and Questions
  1. #811
    Jun 2015
    Hi All,
    Could someone tell me if its possible to get the dealer to add on the DAP package after the car has been delivered?
    really interested in the DAP package, didn't think to get it added on before delivery. Currently have a 90 TSI Comfortline
  2. #812
    2015 90 TSI Golf Comfortline manual transmission.
    Hello all I took delivery of a new 90TSI manual Golf comfort line yesterday and have the following queries.
    1. The aircon automatically turns on when I turn the blower fan on. The temp setting is at the midpoint 22 degrees. Is they any way of preventing the aircon automatically switching on.
    2. How does one dim the instrument panel and steering wheel buttons illumination.?
    3. Apart from muting the radio is it possible to turn the radio off and leave the infotainment screen on in vehicle status mode?
    4. Having transitioned from a 1.9TDI Polo manual, can you give me some running in tips for this petrol engine Golf.
    Like should I maintain a rev limit of 3000rpm for gear shifts 2/3/4/5/6 up to 1000kms and then gradually increase the revs through the rpm range during gear shifts upto 5000kms???
    5. As mentioned in this forum the drivers wiper doesn't have a clean sweep action with the rubber visibly having a juddering action. Any solutions for this??
    6. The USB point in the lower console doesn't seem to charge the GPS unit as I realized it today. Looks like the 12v ciggie lighter slot is the only charge point available??
    7. Does the DRL actually utilize the low beam light or is it a different light bulb i.e. parking light bulb??
    A fair few queries above I hope you guys can help me out. Thanks
  3. #813
    Jul 2013
    2. There should be a dial looking thing to the right of the steering wheel next to the headlight switch, this adjusts the interior lighting brightness.
    5. Try bending the wiper, it shouldn't snap but be careful.
    7. The dipped beams are either the same as the drl but brighter or a completely different bulb. Not completely sure.
  4. #814
    There is only a headlight adjusting dial next to the lighting switch.
    The owners manual covers golf/ gte/gti/gtd and has everything under the sun but vague about the questions I have raised. There is a massive section in this manual devoted to hybrid engines and their heavy duty batteries.
  5. #815
    Apr 2013
    I'm also curious to see if (3) is possible
  6. #816
    Feb 2015
    Wollongong
    Quote Originally Posted by JITHEN View Post
    The DRL has its own filament, the bulb is a H15 15/55w. 15 watt for the DRL and 55w for the High beam.
    As far as the wipers go get a set of Bosch Aerotwins, I changed mine a month after buying my Comfortline.
    Aerotwin A864S - Set of 2 - Bosch Auto Shop
  7. #817
    Righto thanks for that. I'll pick up those Bosch aero twins ASAP. Cheers
  8. #818
    BTW guys I reread the manual last night and found that the panel illumination is adjusted either through the dial next to head lighter adjuster or in cars without that adjuster the illumination can be adjusted through the infotainment system by pressing the CAR button and going through its sub menu. Will try it today.
    However I am none the wiser regarding the air con starting by itself when the blower is activated.
  9. #819
    Mk7 Golf TSI & TDI - Observations and Questions yeah I've spent long hours burning the midnight oil analyzing that manual. And some answers are proving elusive. Any help forthcoming would be great.Mk7 Golf TSI & TDI - Observations and Questions
  10. #820
    Feb 2015
    Wollongong
    I think that only happens if you have the recirculate mode on.
