Page 72 of 109 FirstFirst ... 2262707172737482 ... LastLast
Results 711 to 720 of 1081
Thread: Mk7 Golf TSI & TDI - Observations and Questions
  1. #711
    Jul 2014
    Tasmania
    I desperately would love more power out of my 103, especially top end.
    But the 7 speed dsg wouldn't be able to handle more that the 250nm it already has.
    I hope oped the polo gti comes out with this motor, so that APR can release a tune that I can take advantage of!
  2. #712
    Erskineville, NSW
    Quote Originally Posted by BCK View Post
    The 250Nm is a rating not an absolute. It's like a road bridge that has an engineering rating of 10 tonnes - if you drive a 12 tonne truck over it, it won't collapse or do immediate damage. Maybe as a result you have to upgrade the preventive maintenance schedule or similar but it isn't a show-stopper.
    I think DKtuning & revo might have a map for the 1.4tsi
  3. #713
    Mar 2012
    Sydney NSW
    The 250Nm is a rating not an absolute. It's like a road bridge that has an engineering rating of 10 tonnes - if you drive a 12 tonne truck over it, it won't collapse or do immediate damage...
    Limits are limits for a reason - If you push it , it simply will not last as designed. Like a bridge - it will break
  4. #714
    Erskineville, NSW
    Quote Originally Posted by bennjamin View Post
    You don't know the difference between an engineering rating & a limit
  5. #715
    Bennjamin: I do agree with you that "limits" (however they are intended to be applied) should not be ignored. You make a good point but, except in the most basic circumstances, I don't believe that limits are "absolute" values.
    In engineering terms, absolute limits apply generally only when isolated components are involved. For example, the absolute breaking limit (under tension) for a simple steel wire which is of a certain diameter and is made of a known grade of steel can be determined quite accurately. But, put that same piece of wire in the wheels of a road bike (say) and the limit of the bike as a whole gets much more complex!
    I suspect that the NM rating on a car suffers pretty much from the same problem. The rated limit that the good Burghers in Germany apply to the Golf has to be a compromise between a lot of contradicting factors (maintenance interval, component replacement times, stress on individual components, driving conditions over time, etc). It's difficult to say whether the engineering in a bridge is any more (or less) complex than a car, but with something like a car "limits ain't limits" (IMO).
  6. #716
    Oct 2010
    Seeking feedback
    I have a 2013 Mk7 Highline diesel DSG.
    I have noted the following and would like to find out if others are experiencing the same and advice on what can/should be done
    1) Slow take off and have to push the accelerator down considerably before car moves off.
    2) Uses more Fuel economy than my previous Mk6 diesel Comfortline DSG
    3) First start up of engine of a day have noticed intermittent rattling noise, metallic in nature but seems to go away after a while
    Any assistance/advice greatly appreciated. Thanks
    Golf 2013 Highline 110 TDI White Driver Assist
    Previously-Golf 2010 Comfortline Silver TDI DSG
    Previously VW 1970 Beetle
    Previously VW 1969 Type 3 Squareback
  7. #717
    Jun 2013
    Gold Coast
    1) personall have not noticed this in ours
    2) yep, can agree. Pretty disappointing. We initially purchased ours hoping for good economy, especially at the time when diesel was heaps cheaper than petrol. Having said that, we are lucky to drive more than 15k twice daily. Diesels hate that. Our current long term is 6.9 and average speed is in the 20's
    3) pretty normal for initial startup of a diesel to be noisy.
  8. #718
    Nov 2013
    AUS
    Quote Originally Posted by ecka View Post
    I have adjusted to this annoying trait by anticipating lights or openings in traffic and releasing the brake 1 second earlier. Once you feel the car moving forward, application of the throttle should be the same as a normal torque converter automatic. This minimises excessive throttle application and experiencing driveline shunt and chirping of the wheels.
    It still annoys me but the remainder of the DSG driving experience has been great otherwise (with the exception of the occasional squeak I've had recently when changing from 2nd to 3rd gear).
  9. #719
    Ecka: regarding your (1) point, I think that you are referring to the car's "turbo-lag". I suspect that the mk6 had this also but that it was masked by the super-charger which kicked-in much earlier in the rev range . I have the petrol engine and the same thing happens, but I'm not sure if the effect is more pronounced in a diesel motor. Like "veew" I also have found that with time, I've learnt to find the sweet-spot on the pedal's travel thereby by-passing the dead part of car"s acceleration. Now I don't notice the turbo-lag at all.
  10. #720
    Mar 2007
    Hobart
    From what I've read the EA211 is direct injection only - not port/direct as per the EA888. Can anyone confirm this is definitely the case? If this is the case, I assume the EA211 will suffer the same coking issues afflicting all other VAG DI-only engines?
    2018 Golf GTI, Manual - gone.
    2017 Golf 110tsi Trendline, manual (gone - gladly)
    2007 Golf GTI, Manual, (gone - sadly)
    1978 Golf GLS; 1972 Superbug, (memories)
