Page 495 of 495 FirstFirst ... 395445485493494495
Results 4,941 to 4,948 of 4948
Thread: Mk7 Golf R Discussion Thread
  1. #4941
    Oct 2016
    Waiting to hear back from the dealership on the issue with our 7.5 Golf R Wagon.
    Early comms doesn’t look good…” “Cylinder 3 misfire was found, swapped around spark plugs, fuel injector's and ignition coils.
    Misfire was still evident, carried out a compression test on cylinder 3 and found to have 40 PSI.”
    So, worst case scenario, if I need a new engine, is there anything I should look to add/modify at the same time? The rest of the car is stock, and only done 77K
  2. #4942
    Jul 2009
    QLD
    Wow the 8.5 R seems to have raised the bar, may be tempted to upgrade next year.
    https://youtu.be/xzGrUBi2fGc?si=DTSXaMdkVVWI-nFQ
  3. #4943
    My 2018 7.5 Golf R has hit 30k km and I am wondering about the DSG service. According to this thread, it should be 120,000 kms / 8 years. Some posts (potentially overseas) say it's purely distance based. Has anyone got a definitive steer?
  4. #4944
    Pacific Paradise QLD
    60,000km seems to be the norm for most models and is part of that service
  5. #4945
    Quote Originally Posted by Matticus View Post
    The DSG is due to be serviced either every 4 years / 60,000km. So given your car is a 2018 model, it "should" have already had the DSG serviced based on time a few years ago. Also important is the Haldex to be serviced and have the little filter cleaned (VW do not clean the filter).
  6. #4946
    Thanks! Log book says no for the 5 services at a VW service centre, which is why I am confused. I might need to call them tomorrow and double check. I did the Haldex last year
  7. #4947
    If the car has had “capped services” then this will explain it as they only do the bare minimum. Id be booking it in to get done as soon as your budget allows.
  8. #4948
    Feb 2025
    I'm looking to retrofit a 9.2-inch Discover Pro Delphi unit into my Mk 7 Golf R (MIB1). But I can't find a RHD fascia with air vents on Aliexpress. Where can I buy the fascia for cheap?
