Page 411 of 495 FirstFirst ... 311361401409410411412413421461 ... LastLast
Results 4,101 to 4,110 of 4942
Thread: Mk7 Golf R Discussion Thread
  1. #4101
    Apr 2017
    belgrave victoria
    Quote Originally Posted by SW33 View Post
    When you say 600nm ‘with a tune’, do you mean a tcu tune?
    Yep a new tcu program Harding performance is just about to release its dq381 tune early next year tho they say that the new 7.5 r with the 7 speed vs the 6 speed dq250 they can tune it for a extra 20kw and 80 nm over the plain 7.0 version just because of the beefier gearbox
    Also apparently the tune is optional on a stage 1 tune with 260kw and 520nm! so they think a stock no tune dq381 will handle that much grunt (i have been told by another vw tuner that the clutches in the dq381 are "massive")
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
  2. #4102
    Apr 2014
    I'm presuming tunes will void the warranty though?
  3. #4103
    Jan 2016
    Perth
    Quote Originally Posted by Kachingg View Post
    I got a different response from them on this question. The increased power/torque was not them doing more aggressive with the tune, but rather something they couldn't explain other than VW coding changes (they confirmed engine/turbo were identical). Have a look at question/comments on youtube video.
  4. #4104
    Apr 2017
    belgrave victoria
    Quote Originally Posted by WallySimmonds View Post
    Yup as always if something goes wrong and you have a tune that is picked up its your baby
  5. #4105
    Apr 2017
    belgrave victoria
    Quote Originally Posted by toggle View Post
    Hmm that is interesting i did not read the comments i took from the video him saying more power from stronger gearbox i will go back and check thanks
  6. #4106
    Mar 2010
    Just dropped my car off to Dan for my paint protection. Will post photos once I get it back 😁
  7. #4107
    Jan 2016
    Perth
    Quote Originally Posted by Hole46 View Post
    I did my Tiguan with OBDeleven.
    Got instructions on how to do sat nav nag screen off fix using OBDeleven?
    Have seen some vcds instructions only (5F-> Byte 23 -> 00 (uncheck all) but wasn't obvious to me how to do the same in OBDeleven
  8. #4108
    Jan 2012
    Newbie - Help with how to! | OBDeleven
    2015 Golf R. Lapiz Blue.
  9. #4109
    Jan 2016
    Perth
    Quote Originally Posted by Reedy View Post
    Thanks, will try shortly!
  10. #4110
    Jan 2016
    Perth
    Whilst on the subject, anyone tried swapping water temp with oil temp as default on AID?
    Have seen the odd vcds/obdeleven instruction but unsure if this works on the 7.5.
