Page 303 of 495 FirstFirst ... 203253293301302303304305313353403 ... LastLast
Results 3,021 to 3,030 of 4942
Thread: Mk7 Golf R Discussion Thread
  1. #3021
    Apr 2014
    Quote Originally Posted by hainsey View Post
    It is NOT detectable by VW as I "know a guy" ... hint....hint, who had his turbo fail once tuned and limped it back to the apr tuner and flashed back to stock and re-installed factory air box, got it towed from the performance shop through vw roadside assist to VW dealer and they tried to say it was tuned but could not prove it, even sent the ecu file to Germany for 3 days before they carried out any work, i even told them it was the turbo that shat itself.
    Outcome was new engine and turbo and exhaust from turbo to cat and a BIG warranty on the work carried out, just ensure what model turbo you have ,aka revision, because if you have one of the faulty ones there should be no questions asked as if you have the newer one they might look into it deeper.
    You have to remember that VW cannot refuse warranty on "suspected" mods, they have to prove they have been done, as "here say" won't hold up.
    nevertheless, the APR tune is golden. and I will be going stage 2 a DSG tune.
    I've heard the same thing and spoken to another person with same information. I'm confident that it's not traceable either but it seems frowned apon to say that without being 100% positive. Totally agree APR tune is great and stage 2 and DSG tune and should be totally awesome!
  2. #3022
    Townsville, QLD
    I would have been led to believe that releasing a car that had faulty turbos was frowned upon but ohwell, for a car that is the 40th anniversary of an icon you would think that the build quality would be a ****load higher but unfortunately it isnt
    2014 Limestone Grey Mk7 Golf R
    DSG, Leather, Drive assist.
    APR Carbonio Intake // APR Boost tap // APR Stage 1
  3. #3023
    May 2012
    At the end of the day it's still just a Volkswagen, not a Merc or BMW or Audi.
  4. #3024
    Townsville, QLD
    Audi is the same car and for bmw you pay 75k for a basic 3 series with no options
  5. #3025
    Quote Originally Posted by mp2811 View Post
    Stage 1 is reasonably easy to revert to stock as it's just software bits and bytes. However when you go stage 2 and change exhaust systems there's more involved to revert to stock. There will also be tell-tale signs that things have been done as all the exhaust fixings will be clean/had spanners on them rather than a stock car which likely won't have been touched since leaving the factory.
    If you modify suspension and wheels etc then more often they'll also suspect that you've also done some performance mods also. 90% of the time they'd be right
    Jan 2011
    Brisbane - QLD
    I think i have said this too often but gotta pay to play
    I mean stock 7R 5s 0-100 is heaps on public roads yet stg 1 is still needed to go to and from Westfield carparks Mk7 Golf R Discussion Thread
    MINI Cooper S Clubman - FWD
  7. #3027
    Apr 2011
    Sunshine Coast, QLD
    The Golf R Wagon appeals to my head, more so than my heart. I find the looks of the hatch more compact, hence more go-kart like. But man, that extra boot space would be handy!
    There were criticisms a few years ago that the wagon was based on a previous, outdated platform, rather than the current one (hence the handling was not as good) . Does anyone know if that is the case here?
    Sent from my Nexus 7 using Tapatalk
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
  8. #3028
    Jun 2013
    Quote Originally Posted by cheapasiangeo View Post
    It doesn't have to be the same. There are plenty Merc and BMW models which are worst than VWs.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  9. #3029
    Apr 2014
    Quote Originally Posted by RoknRob View Post
    I'm pretty sure it's now based off new platform and the couple of reviews I read stated it even handled better than the hatch in their opinion. The slightly longer platform helped it to handle even better through corners.
    I'm not a fan of wagons but can definitely see the appeal and advantages to the extra room.
  10. #3030
    Apr 2013
    A poor man's RS4, but I certainly dig it
    MY14 MK VII GTI | Pure White | Manual | Bi-Xenons (his)
    MY19 B8 Passat 206TSI wagon | Manganese Grey (hers)
