Page 217 of 495 FirstFirst ... 117167207215216217218219227267317 ... LastLast
Results 2,161 to 2,170 of 4942
Thread: Mk7 Golf R Discussion Thread
  1. #2161
    Quote Originally Posted by TJG View Post
    I looked in the manual for how to change the key fob battery - Once I had the cover off the key it was pretty straight forward.
    Yep I figured that but how the heck does the cover come off?
    Last thing I want to do is break it...
  2. #2162
    Apr 2014
    Albany Creek, Qld
    Quote Originally Posted by jonoz View Post
    Yep I figured that but how the heck does the cover come off?Last thing I want to do is break it...
    Open key and stick 10 cent coin (or something similar) in slot where key sits and twist. Cover should pop up.
    Mk7 Golf R Discussion Thread-key-jpg
    and opened
    Mk7 Golf R Discussion Thread-openkey-jpg
    You will need a small torx driver to undo this screw.
    Have fun
  3. #2163
    and opened
    Have fun
    You should totally post this under the guides section... Mk7 Golf R Discussion Thread
    Immensely helpful, thanks.
  4. #2164
    Is it normal for the R to emit a high-pitched noise when you use the keyless entry?
    For example, the key is in my pocket, place my hand on the door handle and the car unlocks and emits this high-pitched buzz almost. Is it just supposed to be audibly letting you know the car is unlocked?
  5. #2165
    Sep 2012
    Darwin
    Pretty sure its your exterior lighting turning on (headlights/tailights or just angel eyes)
  6. #2166
    Townsville, QLD
    Mine does the same thing, and is coming from the front of the car so it should be that
  7. #2167
    Apr 2014
    Albany Creek, Qld
    I think you are hearing the whine from the xenon lights that turn on when you unlock the car. Mine does it and so did my Mk6 (but it was much quieter).
  8. #2168
    Jun 2013
    QLD
    Apr 2014
    Speaks highly of the Golf R that's it's nearest competitors here are at $20K more. I wonder how AMG will go once fairly compared to RS3 and Golf r400 etc
  10. #2170
    Thanks for the input regarding the key and noise.
    Is there any attenuation option regarding the navigation? The only option I can find is the volume level for each media type and to turn up the volume on navigation?
