Page 214 of 496 FirstFirst ... 114164204212213214215216224264314 ... LastLast
Results 2,131 to 2,140 of 4951
Thread: Mk7 Golf R Discussion Thread
  1. #2131
    May 2011
    Albury / Wodonga
    I suppose the original black plate is an ADR thing
    Looking for:- RS4 B7 Avant.
    Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
    Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
  2. #2132
    Quote Originally Posted by armthehomeless View Post
    For those who may not have seen it in the other thread, I removed the front number plate mounting on my R:
    http://www.vwwatercooled.com.au/foru...ml#post1082749
    I think it looks better.
    Going through your other vids! Northsider!!!
  3. #2133
    Jun 2013
    QLD
    Jan 2012
    Epping, NSW
    Quote Originally Posted by 1WD View Post
    Hey Tony, you might want to read this, you're in luck!
    ISOFIX child car seats finally approved for Australia: Car News- CarsGuide
    Nup, apparently from the standard, it takes a year or two for the seat manufacturers to get approved still, Britax will have first one sold here soon, and it isn't for babies, only front facing. We are not allowed to import other standards approved ones
  5. #2135
    Jun 2014
    Perth
    Hey guys, test drove the R and the GTI-P yesterday and I found the R more planted n more exciting. It felt like it had more to give as you rev it towards the redline compared to the GTI which felt a bit flat to me. while the GTI is definitely fast enough for me as a daily drive, I find myself wanting to go with the R because of the manic acceleration n the 4wd platform.
    The only issue I have with the R is the drone. Is this an exhaust drone or is it part of the artificial sound that is pumped in through the speakers and if so, can it be disabled? I found the drone really annoying after a while. Is anyone else bothered by it?
  6. #2136
    Townsville, QLD
    It is a bit of both mate with the drone, did you try driving the car in comfort or Eco, because in race it is definitely more noticeable but with the others it does tone it down a fair bit, the soundaktor is definitely louder in race above 3500rpm, or so it seems, even when engine isn't under load
    2014 Limestone Grey Mk7 Golf R
    DSG, Leather, Drive assist.
    APR Carbonio Intake // APR Boost tap // APR Stage 1
  7. #2137
    Central VIC
    In comfort mode or Eco mode on the freeway I've had no issue with drone. Sometimes on change down to the lights it can drone a bit however the soundakator mod is quite effective at toning it down a tad if required (I had it adjusted to 75% which was perfect).
  8. #2138
    Mar 2014
    Queensland
    Like you I find the drone a bit annoying but have owned the car a few months and find it less problematic now. I found that if I travel at lower speeds with the roof open the drone is significantly reduced.
    I don't find the highway drone bad at all but the drone that develops when engine braking/ slowing down when approaching intersections is bad and is certainly exhaust related. My Soundakator has been turned off - the engine sounds great.
    I talked to VWA and they aren't interested at all despite the fact that the low speed drone could be eliminated with a simple adjustment to the butterfly valves (in the active exhaust) to close them when decelerating and below 1600rpm. After all that is one reason you have an active exhaust.
  9. #2139
    Mar 2014
    Queensland
    I should say apart from the wing above, I absolutely love the R. It has the perfect combination of performance, ride quality, subdued style and stunning handling for me. I just love it and look forward to driving it whenever I can. Easily the best car I have ever owned!
  10. #2140
    Quote Originally Posted by Benz View Post
    Hey mate, how did you go about getting the Soundaktor turned off? I have read through the Soundaktor thread but did you get the dealer to disable or elsewhere? Just wondering if its going to be something missus would dislike so wondering how easy it would be to flick on/off.
