There you go.
Only new cars I have had previously have been Japanese, with 6.7 and 5.2 respectively.
Thanks for setting me straight!
There you go.
2014 Mk7 GTI|Pure White|Manual|Tint
here is a video of my golf R and how the cadiz look spinning
https://www.youtube.com/watch?featur...&v=P070gLgDv_4
Perry, I have an A4 1.8TFSI that uses at least a couple of litres of oil a year between services. A known problem with some of these engines. Made worse with the CVT in mine. I would put a litre of oil in yours and service it in two months or just before you sell it. Alternatively book it straight in for a service early next week and ignore the low oil for a couple of days.
Can a mk7 R owner answer a question I have please?
On the R headlight, what is the light in the small area? (Yellow box in below image)
I know there is a corner light on the side of it and the U shape DRL, but is there anything else there or is it just for decoration?
Thanks
This is another horseshoe DRL, exclusive to the R. All Bi-Xenon fitted GTI models only get a single DRL per side. However, if it's the internal light you are refering to, this is the halogen high beam for flashing, but also suppliments the Bi-Xenon lamp in high beam mode.
Found a review about new golf R
and another one on the track
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
the front bit in the middle does not seem to do anything. but if you look from its side, inside there is a halogen bulb for static cornering lighting (in conjunction with the dynamic bixenon for cornering). similar in Tiguan bixenon headlights.
high beam would be from the bixenon only.
below is bixenon from non R golf 7.
MINI Cooper S Clubman - FWD
Many thanks Perry! Good choice on the colour and interior combo IMO. Enjoy mate!
As a matter of interest on the topic and in no way related to VW, I know that Mercedes used to (and may still) be able to reset the Km's on their cars to zero a certain number of times if they were under a certain number of Km's (if my memory serves correct it was somewhere in the region 3 times under 100kms). So your 'brand new' almost zero km car, may in fact have done a few hundred K's through the process of a PD service and test drives etc. Personally, I think I would prefer to know the real K's than be under the illusion that it had done no K's.
