Page 106 of 495 FirstFirst ... 65696104105106107108116156206 ... LastLast
Results 1,051 to 1,060 of 4947
Thread: Mk7 Golf R Discussion Thread
  1. #1051
    Mar 2014
    Melbourne, VIC
    From what I've seen the DSG just about always weighs 20kg more than the equivalent manual
    From the VGA brochure of the Golf Performance Range, why is there a discrepancy in weights between the manual and DSG variants of the GTI and R, as per:
    GTI Manual: 1313 kg
    GTI DSG: 1324 kg
    Difference: 11 kg
    R Manual: 1416 kg
    R DSG: 1435 kg
    Difference: 19 kg
  2. #1052
    Mar 2014
    Melbourne, VIC
    Manual Transmission vs DSG
    Has anyone ordered or is thinking about ordering a manual transmission R? Given that the overwhelming majority of orders will be DSG models, does this mean that manual transmission models will become orphans at time of resale? Is the GTI situation the same? Professional road testers have lamented the non-availability of the GTI PP in manual, but perhaps VGA have read the Aussie market correctly.
  3. #1053
    Mar 2014
    Melbourne, VIC
    Quote Originally Posted by sekas View Post
    My car arrived at the dealer today pickup is scheduled for tuesday but may get it monday.
    From the photo of the front number plate holder, it's going to be impossible for Lakin Custom Plates Brackets to produce an aluminium substitute of smaller dimensions utilising the existing 4 outer mounting points. Non-Euro standard size number plates will look out of place amongst a sea of ugly black plastic.
  4. #1054
    May 2011
    Albury / Wodonga
    Quote Originally Posted by Mikey1 View Post
    Very good question. I've been wondering this myself. Although I have ordered an S3 I am considering changing from manual to S-tronic partly due to resale issues. I suppose the best barometer will be how easily those with manual GTI and R Mk 6s shift theirs as they sell them over the coming months.
    Looking for:- RS4 B7 Avant.
    Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
    Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
  5. #1055
    Central VIC
    Clearly the market for a manual R (even more so an S3 where very very few buyers will chose a manual) will be very limited (which is why there will be no manuals supplied by VW until September some 6 mths after the R's release; I imagine Audi took a similar approach with the S3). Clearly come resale time your potential market will be small. You might be lucky and find one of the few in the market at the time. However, it will no doubt be harder to sell. The manual performance market is more focused on the hard core hatch/sedan, focus ST, renault megane RS265, WRX etc
    Personally, I think the big problem with manual R's/S3'S is that the 6 speed VAG DSG/S-Tronic is so good! Its tried and tested and really an incredible transmission still delivering real driving thrills to the driver both acoustically (dsg farts ) and some sense of connection/control to/of the transmission (i.e paddle shifters) unlike the slush box autos or worse CVT's (the latter are horrid- currently driving a loaner Outback and the CVT is insipid and uninspiring). You get a lovely distinct gear change with the DSG and as a bonus it sounds great. Its a sinch to drive in busy city traffic, but when you put the foot down it feels like youre in an F1 car with explosive lightning fast gear changes
  6. #1056
    I could be wrong but isn't that the same as the Mk6? If you weren't mounting a full size plate you either used a Lakin bracket within the Euro holder, or removed the Euro holder and used plugs to fill the holes.. pretty sure that's how it was on my GTI. I am going Lakin on the back to avoid wide drill holes in case I ever end up with smaller plates - for now I'm going to run full sized Euros.
  7. #1057
    Apr 2013
    Yeah but on the mk 6/7 GTI/R (4 different cars) the holes are in 4 different spots. The Mk7 R has them almost in the corners. It's definitely the worst of the 4 in terms of being able to slim it down with a custom bracket. There's not much Lakin can do with the Mk7 R
  8. #1058
    Mar 2014
    Quote Originally Posted by Jimi View Post
    As discussed in the separate thread on this topic, Philip from Lakin does offer another solution, whereby the 4 holes are plugged with perfectly colour-matched plugs (which come from USA) then create smaller spaced holes which accommodate any size bracket in the future (mentioned by Dutch77 above). I seriously considered this option, but instead went for an albeit smaller bracket fitting the existing holes; my plate is slimline 372x100 so the bracket protrudes 7 cm each side, but will still look OK (I will have black and white plates on a black bracket on a white car).
    Philip does not understand why VW insist on sending a full-size Euro bumper with the GTI and R, and (yet again) it shows a lack of understanding of the Australian situations. I asked my dealer about it. He said the bumper protects important things that sit behind it. (??!?)
    2014 Mk7 GTI​|Pure White|Manual|Tint
  9. #1059
    Apr 2013
    CT69 I've gone down exactly the same path as you. Fortunately the GTI plugs are closer together
  10. #1060
    Quote Originally Posted by CT69 View Post
    The bumper might but that bracket certainly doesn't! Unless he's referring to the bracket.. which then makes a mockery of 4WDs fitted with big bull bars - all they need is a Euro plate holder.
    Agree that the fitment direct from factory doesn't make sense, especially when the lower models in the range come with a clean bumper.
    The Lakin plug solution is what I figured was the alternative, it's not perfect but probably still looks better than a slim plate mounted to the full sized bracket, unless you are like CT69 and working with white and blacks direct.
    Anyway whether the bracket is there or not, Lapiz Blue is hot and would be my choice for the classy look (followed by grey with black wheels for the sports look).
