Page 491 of 496 FirstFirst ... 391441481489490491492493 ... LastLast
Results 4,901 to 4,910 of 4952
Thread: Mk7 Golf R Discussion Thread
  1. #4901
    Jun 2021
    The water pump is about $630 in parts and then about 4 hours labour, so I would have thought your quote was about right. Might be worth ringing around a few other VW specialists to get some other quotes though just to be sure.
    06L121012L & 06L121111M - Water Pump & Thermostat Housing Bundle (MQB) – VAGPARTS Australia
    Definitely look at your service history and check whether the Haldex has been serviced. VW only specifies that the oil is changed, but there is a little screen filter that clogs up with metal filings that should also be removed, cleaned and refitted. I have seen heaps of photos of Haldex cars with 30-40,000km on them and this filter is already full of debris.
    As for R badges, just look on ebay. You will find both genuine and Chinese replicas and you choose whichever you want based on what you are willing to spend.
    Thanks, was advised not to replace the water pump unless it was leaking.
    Ended up getting the oil changed (previous owner got it changed at Kmart/Mycar in May, completely wrong oil used) + haldex service, there was some gunk in the screen filter, have definitely felt the rear engage more in some full throttle applications.
    Now I'm just waiting on clutch to go so I can upgrade it and get a stage 1
  2. #4902
    Quote Originally Posted by gully2020 View Post
    Of course, would be silly to spend $1k+ on something that hasnt broken yet. The waterpump on mine is leaking a tiny little bit, im just keeping an eye on it and will replace it when the time comes.
    Good news.
  3. #4903
    Sep 2010
    Besides the MIB2 radio, is there anything significant that an MY16 car has over an earlier MY14/15 one? I plan to do a MIB2.5 retrofit at some stage, so the easier to upgrade, the better.
    I'm specifically on the lookout for a stock tornado red or candy white DSG R with low kms.
    '18 MY18.5 MK3.5 Octavia vRS245
    Previous - 2015 MY16 MK7 R, 2010 MY10 R36 DSG, 2010 MK6 Golf GTI DSG // APR Stage 2, 2006 MK5 Jetta TFSI DSG // Revo Stage 2, 2006 MK5 Golf GTI Manual
  4. #4904
    Mar 2016
    QLD
    Quote Originally Posted by whichonetoget View Post
    Leather became standard
    Sent from my Samsung Smart Fridge
  5. #4905
    Jul 2020
    Outback
    MK7 R with IS38 LM440 Turbo Upgrade: It also fits Tiguan, Passat B8, Cupra, all MQB (2013-2020)
    The IS38 LM440 Upgrade Turbo in other 2.0 Gen.3 MQB cars with LOWBOOST and EXTREMEBOOST Stage 3 Remaps:
    SPOOL-BOOST: 6. + 5. Gear
    2400 rpm = 1.26 bar (18 PSI)
    2500 rpm = 1.62 bar (23 PSI)
    2700 rpm = 1.97 bar (28 PSI)
    Stage 3 (ECU & DSG)
  6. #4906
    Jul 2020
    Outback
    MK7 R Variant with LM500 upgrade turbo tuned last weekend:
    521 hp | 650 nm torque | DRAGY accelerations:
    Stage 3 (ECU & DSG)
  7. #4907
    Jul 2020
    Outback
    Cupra (also MK7 R engine) mit 520 HP reviewed by AutoTopNL:
    Stage 3 (ECU & DSG)
  8. #4908
    Jul 2020
    Outback
    Reviewd by AutoTopNL - 2. detailed part: LITTLE IS38 Upgrade Turbo LM440 in Golf MK7 TWIN called VAG Seat Leon CUPRA:
    (built engine with hardcore remap)
    Stage 3 (ECU & DSG)
  9. #4909
    Jul 2022
    Hi all,
    New Mk7R owner here.
    Would anyone have recommendations for an R specialist workshop in Sydney?
  10. #4910
    Aug 2015
    Quote Originally Posted by SiebenR View Post
    Hi all,
    I’d be interested to hear peoples thoughts on this too Mk7 Golf R Discussion Thread
