I'm presuming tunes will void the warranty though?
Yep a new tcu program Harding performance is just about to release its dq381 tune early next year tho they say that the new 7.5 r with the 7 speed vs the 6 speed dq250 they can tune it for a extra 20kw and 80 nm over the plain 7.0 version just because of the beefier gearbox
Also apparently the tune is optional on a stage 1 tune with 260kw and 520nm! so they think a stock no tune dq381 will handle that much grunt (i have been told by another vw tuner that the clutches in the dq381 are "massive")
2017 Golf Alltrack 135tdi All options
19 inch Brescia Wheels Golf R brakes front and rear
Calipers painted Candy apple gold
New rear sway bar and linkages
I got a different response from them on this question. The increased power/torque was not them doing more aggressive with the tune, but rather something they couldn't explain other than VW coding changes (they confirmed engine/turbo were identical). Have a look at question/comments on youtube video.
Just dropped my car off to Dan for my paint protection. Will post photos once I get it back 😁
Newbie - Help with how to! | OBDeleven
2015 Golf R. Lapiz Blue.
Whilst on the subject, anyone tried swapping water temp with oil temp as default on AID?
Have seen the odd vcds/obdeleven instruction but unsure if this works on the 7.5.
