Page 406 of 495 FirstFirst ... 306356396404405406407408416456 ... LastLast
Results 4,051 to 4,060 of 4947
Thread: Mk7 Golf R Discussion Thread
  1. #4051
    Jan 2016
    Perth
    Great thanks! What else you configured?
  2. #4052
    Apr 2014
    Albany Creek, Qld
    Not much - Traffic (TMC), Indicators (4 Blinks) and Nag screen off. I will do more over time as I find things that annoy me
  3. #4053
    Android auto will not display on the speedo screen, only on the central discover pro screen. So if you use Google maps nav you will not be able to have it displayed in front of you. Also, you cant have the speed signs displayed on the speedo screen either, it only seems to be displayed on the central discover pro screen.
    Regarding the speed signs being picked up by cameras, yes it does work, although i dont think its activated in australia. I thought mine was updating quite fast. although after doing some testing, im pretty sure its working on GPS location.
  4. #4054
    Does the TMC work well for you? Ive thought of activating it, but not sure if its worth showing a flash just for that.
  5. #4055
    Apr 2014
    Quote Originally Posted by wookie_666 View Post
    Doesn't the Audi version do that though? Seems odd that they'd leave it off the VW version if so.
  6. #4056
    Sep 2012
    I've activated both TMC and the "Dynamic Road Sign Display" (speed limits) through OBDeleven and both work fine and display in the AID.
    TMC will show the coloured lines for traffic congestion on the AID while on the Discover Pro screen you get that plus warning signs that can be touched on for more information about the delays.
    The Dynamic Road Sign Display works through the camera at the top of the windscreen. It is working ok with the new electronic signs on Citylink in Melbourne. The only problem I've found is in school zones where they display the lower limit and the times applicable - so it just shows 40 as the permanent speed limit.
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
  7. #4057
    Jan 2016
    Perth
    Quote Originally Posted by TJG View Post
    Thinking of getting an OBDeleven rather than rely on independent to make changes with VCDS. Any reason to think OBDeleven can't do nag screen off fix? Curious if OBDeleven can do anything VCDS can do.
  8. #4058
    Nov 2016
    MAPLETON Qld
    I did my Tiguan with OBDeleven.
  9. #4059
    Apr 2014
    Albany Creek, Qld
    Quote Originally Posted by toggle View Post
    I have a VCDS cable so I haven't used OBDeleven, but from what I have read I would be very surprised if you can't do it with OBDeleven.
  10. #4060
    Jan 2016
    Perth
    Do our 7.5R stereos have support for digital radio?
