Page 265 of 495 FirstFirst ... 165215255263264265266267275315365 ... LastLast
Results 2,641 to 2,650 of 4947
Thread: Mk7 Golf R Discussion Thread
  1. #2641
    Sep 2012
    Darwin
    Probably, just that if the ECU has the same number/revision then the gains would have to be made somewhere else.
    Who knows.
    Mk7 Golf R Lapiz Blue | RDTechnik Tuning box and DSG Tune | APR Intake | VWR Springs | P3 Gauge
  2. #2642
    May 2011
    Albury / Wodonga
    I thought it was fairly common knowledge that the Australian spec R wasn't really detuned. The main issue being power loss on hot days when a significant amount was lost. From memory 50 Nm on the Mk 6 when ambient in the high 30s was being mentioned by others a few years ago.
    Anyone got actual figures on this?
    Looking for:- RS4 B7 Avant.
    Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
    Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
  3. #2643
    Townsville, QLD
    Also you have to remember that the dyno done in Aus did notice power being made at a different rev band but only slightly different.
    2014 Limestone Grey Mk7 Golf R
    DSG, Leather, Drive assist.
    APR Carbonio Intake // APR Boost tap // APR Stage 1
  4. #2644
    Jan 2011
    sydney
    Do you know whether there been any change to the TD1 flag after an ECU tune - Has APR been able to address this?
  5. #2645
    Jun 2013
    QLD
    Well, the car is in for a tune.
    Did not particularly fill me with confidence in APR making customer's sign a liability waiver prior to undertaking the tune. Whilst I understand that tuning is not normally covered by any guarantee's APR is obviously quite concerned that it does increase the likelihood of turbo failure on the Mk7 R.
  7. #2647
    Townsville, QLD
    Are you putting it on a dyno mate,
    Mine is going in on Wednesday morning
  8. #2648
    Dec 2008
    Perth, WA
    Quote Originally Posted by jonoz View Post
    Interesting, they'd need to be careful on the wording of such a waiver as unless it is 'expected' to blow up your turbo, they cannot make you sign over your rights. Australian law is pretty specific like that (same goes for warranties).
    Good luck, I'm keen to know what you think of it. I'm going to sit by the sidelines for a while to wait and see how this tune turns out (plus my car only has 231kms on it)...
    I think I'll investigate the handling options first. Already looking into a nice set of KW's that integrate with the car's electronic damping. Direct plug and play!
    KW automotive GmbH - Gewindefahrwerke, Rennsportfahrwerke, Sportfedern - Coil Overs
  9. #2649
    Quote Originally Posted by hainsey View Post
    Nah mate not unless a dyno run is included in the tune price. Is it? I didn't ask my motivations are more to get the downpipe on.
    This waiver may certainly edge some more customers Revo's way but as you said it was worded along the lines of, if the turbo is going to fail its going to fail and you cant blame the APR tune.
  10. #2650
    Dec 2008
    Perth, WA
    From what I understand that's true, although the tune can dramatically bring that failure forward somewhat (I read stories of guys who had failures within hours of the tune).
    Everybody is panicking about these turbo failures in any event, I'm sure in the fullness of time the full story/resolution of the problem will come out.
    Cheers.
