Considering guy has done hundreds of dyno runs on there own golf R over a year of development im pretty confident that its safe lol.
Also 'all these turbo failures' theres only been a handful worldwide. And only one reported out of all that have come to Aus.
Mk7 Golf R Lapiz Blue | RDTechnik Tuning box and DSG Tune | APR Intake | VWR Springs | P3 Gauge
According to tuning companies here in Aus. Dont believe the Detuned crap. When tested such as at APR the Aus R they had there which matched mine was dynoed and had the 221KW standard tune.
Believe or dont believe but food for thought.
I know mine got up to 19 stock now around the high 19, low 20
Maybe not son.
21 psi, apr intake only - YouTube
https://www.youtube.com/watch?v=6Qbl6Mcme6k
Video was shot with phone. boost gauge goes up in increments of 5psi to 30 psi.
2014 Limestone Grey Mk7 Golf R
DSG, Leather, Drive assist.
APR Carbonio Intake // APR Boost tap // APR Stage 1
Am I understanding you correctly? They dyno'd a oz spec car, with an oz spec '206kw' engine map, and an oz spec car with an EU '221kw' engine map flashed onto it (or perhaps an EU spec car in Europe on the same brand of dyno?) and both cars generated the same power at the wheels/hubs?
As in yes. An Aus spec one dynoed in Brisbane made exactly the same as one in Germany, 221kw. The ECU numbers are identical apparently etc.
You will actually see it on APR R tune that they just released as well. Where the numbers are, it say official figures stated by factory 206kw ...figures actually on the dyno 'stock' 221kw.
Like i said before, believe it if you want but i have seen proof so i know its true. Although it makes very minimal performance difference anyway.
It sounds like you're saying that an Australian spec was tested and gave a figure more like the Euro numbers on their spec sheets.
If the Aus car and a Euro car weren't tested on the same dyno the number is meaningless. Dynos all read quite differently - they are famously inaccurate - and are only useful in seeing the gains made before and after a mod or by testing two cars on the one machine to compare
Id bet a euro car on that dyno would show ~235kw
