Page 244 of 495 FirstFirst ... 144194234242243244245246254294344 ... LastLast
Results 2,431 to 2,440 of 4947
Thread: Mk7 Golf R Discussion Thread
  1. #2431
    Apr 2014
    Thanks Jonoz, looks fantastic!
  2. #2432
    Quote Originally Posted by jonoz View Post
    Milltek exhaust is in the boot!!!
    Whats the feelings about running the TBE without the tune being ready yet?
    Hey mate, did you go a resonated exhaust or non resonated?
  3. #2433
    Quote Originally Posted by Gary_s View Post
    Non-resonated.
  4. #2434
    Non-resonated.
    You won't be needing that soundaktor anymore Mk7 Golf R Discussion Thread
    I actually asked the dealership to disable it prior to delivery but there isn't any real way to check 100% other than seeing VCDS yourself.
    Low and behold, it was another disappointment from the dealership and I disabled it when I got my VAGCOM cable.
    The Soundaktor was pretty much 100% why I chose the non-resonated due to loving the noise but after disabling it the car changed.
    Still really debating the Catback Vs Turboback install since I have no knowledge of what current ECU's are like. I remember it was somewhere round 04~05 where STi's needed a tune but am adamant that a bugeye was fine without a tune, i.e. no boost creep etc.
    Guessing a '14 Golf is going to be the same where running a Turboback without the tune would be detrimental and my options would be do Catback > Tune > Downpipe or to simply way for the tune to be ready...
  6. #2436
    If it's anything like the Mk6, putting on a larger diameter down-pipe will result in a CEL (Check Engine Light) fault. Generally the way to fix it is with a tune... so suggest waiting on installing the DP until you're ready to tune the car.
    If you want more noise, just installing your cat-back for now. Though for a lot of people non-resonated systems are a little too much for daily driving (speaking from personal experience).
    Worst case if its too loud I can buy the resonated piece and switch it over.
  8. #2438
    Yep. I started non-res and then got a resonator fitted after about a month. It sounded great going for a spirited drive through the hills, but when you're just trying to drive quietly down the street it was almost impossible. Given I use my car for work it's not something that's really suitable to turn up to customers sites (and the wife wasn't keen on it either).
    The R due to being a hatch is the work car of course. Mk7 Golf R Discussion Thread
    Being 26 and unmarried I think I can get away with the non-resonated for a bit and right it off as a rumbunctious period...
  10. #2440
    Go for it! You only live once
