Page 211 of 495 FirstFirst ... 111161201209210211212213221261311 ... LastLast
Results 2,101 to 2,110 of 4947
Thread: Mk7 Golf R Discussion Thread
  1. #2101
    Jun 2009
    Quote Originally Posted by 1WD View Post
    The start/stop button, I think it's a bit un-necessary. Maybe it's me being a bit old-skool. My main gripe with that would be that VGA found it more important to have a start/stop button than a decent nav screen. (I know that it comes down to a final landed in AU price)
    One problem I did have with it was you'd pull up in your driveway and the auto stop/start would stop the car and pressing it again to stop (as you would turn off a key)... It started again! lol
    Something to learn to live with I guess...
    Correct me if i am wrong but the xenon housings still have a halogen bulb for high beams don't they?
    Can't you just get an uprated bulb (osram rallye etc) like i did for my halogen housings.
  2. #2102
    Apr 2014
    Albany Creek, Qld
    I think bi-xenons use xenon for both high and low beam. There is a halogen H7 for static cornering light.
    But I didn't think they were bad (not that I get to use them on high beam too much)
  3. #2103
    Mar 2014
    Melbourne, VIC
    Quote Originally Posted by team_v View Post
    On the Mk7, the inner halogen H7 high beam has been dropped on Bi-Xenon systems. This used to accompany all Xenon and Bi-Xenon systems, and for the latter, the H7 high beam was primarily for flashing/passing duties, as the previous HID design/globe was relatively slow to reach full intensity. However, current HID technology allows for almost instant full luminescence.
    Quote Originally Posted by TJG View Post
    This is correct for the all Mk7's with Bi-Xenon headlights.
  4. #2104
    Jun 2009
    Quote Originally Posted by Mikey1 View Post
    That's interesting.
    So the inner housing on this one contains a bi-xenon bulb?
    It looks like a halogen housing.
  5. #2105
    Mar 2014
    Melbourne, VIC
    That's interesting.
    That inner lamp is nothing more than a position light of low intensity, quite pointless in function, given the brightness of the U-shape DRL's.
  6. #2106
    Jan 2012
    Epping, NSW
    That's interesting.
    I don't think they implied that. You don't need anything on the inner lights I think was the implication.
    On the mk6R, the inner is the indicator bulb, and it looks the same on the mk7 to me (looking at that img on my phone screen in Tapatalk).
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
  7. #2107
    Jun 2009
    Quote Originally Posted by tonymy01 View Post
    The indicator function is provided by the led strip below the bulb housings (follows the silver grill line)
    So is the high beam just a brighter output of the outer xenon bulb or is it the inner bulb?
    If it is the inner bulb, i don't believe it is a bi-xenon as it would require a reflector housing to operate effectively.
  8. #2108
    Mar 2014
    Melbourne, VIC
    The high beam is incorporated in the outer Bi-Xenon projector lamp where the 35W HID bulb operates at maximum intensity when activated. By design, the system includes an electro-mechanical shutter which provides the cut-off on low beam, while on high beam the shutter retracts.
  9. #2109
    Jun 2009
    The high beam is incorporate in the outer Bi-Xenon projector lamp where the 35W HID bulb operates at maximum intensity when activated. By design, the system includes an electro-mechanical shutter which provides the cut-off on low beam, while on high beam the shutter retracts.
    Ahh okay, that makes sense now.
    So to remedy the original problem, we just need to install brighter output bi-xenon bulbs.
  10. #2110
    Mar 2014
    Melbourne, VIC
    HID systems are far more rigid in design than halogen, and therefore AFAIK there is no performance variation to the bulb, other than its lumen colour temperature. Standard 4300K bulbs provide the highest brightness. The higher the colour temperature, the bluer the light will be, and the lower will be its effective brightness.
