Page 152 of 495 FirstFirst ... 52102142150151152153154162202252 ... LastLast
Results 1,511 to 1,520 of 4947
Thread: Mk7 Golf R Discussion Thread
  1. #1511
    May 2012
    Chadstone, VIC
    Anyone in Melbourne with VCDS and micro CAN who can assist with a simple coding of the soundaktor synthesised engine noise for Golf R Mk7? Would really appreciate it. I have the instructions so should be pretty simple.
  2. #1512
    Mar 2014
    Queensland
    7R Interior Noise and Vibration
    Hi all,
    I've had my 7R for almost a month now and put 800 kms on it so far.
    Since new it has had a drumming noise in the interior at around 1400 - 1600rpm on a trailing throttle (say off throttle coming up to an intersection). It is definitely exhaust related as recently I had the Soundakator turned back to 0%. Loving the pure engine sound now but still got the interior drumming.
    Does anybody else have this (minor) issue?
    Also, I pick up engine related vibration through the car (seats in particular) when cruising at around 100 - 110kph. Is this normal or do I have an issue with a crook engine mount or something?
    Any help or comment much appreciated.
  3. #1513
    May 2012
    Chadstone, VIC
    I also get the drumming/low frequency drone at low RPM or when coming to a stop. Pretty annoying actually. I overcome this by manually downshifting gears. Seems to help.
    Don't have the vibrations though. At speed the car is pretty smooth.
  4. #1514
    Feb 2014
    Quote Originally Posted by Benz View Post
    Hi all,
    Quote Originally Posted by RoccoR View Post
    I get the same drumming and pretty much agrees with what's said above. I doubt it can be 'switched' off like the soundaktor. The downshifting is an interesting idea - will have to give that a go and see if it helps when it gets too much during city driving where it tends to be below 60kmh.
    Driving: Golf R Mk7 MY14 - Pure White, DSG, Leather, DAP and Sunroof
  5. #1515
    May 2011
    Albury / Wodonga
    Benz and RoccoR,
    Is this your first R? I'm pretty sure you are describing the exhaust popping on the over run. It did cause me brief concern when I first noticed it on the Mk 6, but now I try to do it as often as I can.
    In the Mk 6 it only seems to happen in first and second and the revs need to be coming down from just over 3000 rpm. I think I remember someone saying about the exhaust valve opening under these conditions which makes it all louder.
    Looking for:- RS4 B7 Avant.
    Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
    Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
  6. #1516
    May 2012
    Chadstone, VIC
    Quote Originally Posted by Paul_R View Post
    Benz and RoccoR,
    Hey Paul R,
    Definitely not the crackle and pop on the over run, if it was that I wouldn't be complaining cos I love that sound.
    This is really more like a low frequency humm / drone. Kinda like when only one person opens a window in the car when you're driving and you get buffeting. Similar to that.
  7. #1517
    May 2012
    Chadstone, VIC
    Not really that concerned about it, just calling it out since someone else did.
  8. #1518
    May 2011
    Albury / Wodonga
    Hey Paul R,
    No idea then.
  9. #1519
    Sep 2012
    Darwin
    Are you sure your just not explaining the exhaust drone??
  10. #1520
    Apr 2014
    Adelaide, South Australia
    Hey Paul R,
    I definitely know what you mean by this, and a very accurate description, I originally thought one of the rear windows were open as it sounded like that sort of drumming noise.
