Results 1 to 8 of 8
Thread: MK7 Golf R AC/Heater Not Working (climate control)
    Feb 2021
    Sunbury, Victoria
    Angry MK7 Golf R AC/Heater Not Working (climate control)
    Hi all,
    I recently purchased a 2014 Golf R and the AC/heater has stopped working. All functions are available on the climate control however, turning the the fan off with the dial does not turn the blower on. Heated seats also dont work.
    Fault codes show errors in communication.
    Fuses have been checked.
    This was an intermittent issue before it completely stopped working. The interior fans would come on randomly, with the climate control off and no user input could turn it off or change it.
    I have purchased a second hand climate control and installed that/re-coded to suit. Blower still doesnt work, heated seats do however the unit is only half lit and doesnt seem to be working properly.
    Has anyone experienced this before? Any ideas what it could be? Is there relays in the system that may be faulty. I am struggling to find information on it.
    Any help would be greatly appreciated!!
    @trom555: post-up a copy of the auto-san so we can see the faults and the equipment on the car
    Feb 2021
    Sunbury, Victoria
    08 Air Conditioning
    System description: Climatronic
    Software number: 5G0907044AA
    Software version: 0805
    Hardware number: 5G0907044AA
    Hardware version: H02
    ODX name: EV_ACClimaBHBVW37X
    ODX version: 003018
    Long coding: 00120014200100001005000012101800
    Trouble codes:
    B108715 - Left vent temperature sensor Open circuit/short circuit to B+
    Intermittent
    Priority: 3
    Malfunction frequency counter: 1
    Unlearning counter: 44
    Dynamic environmental data: 02867A26097EF40D00
    B108815 - Right vent temperature sensor Open circuit/short circuit to B+
    Intermittent
    Priority: 3
    B10E815 - Sunlight photo sensor Open circuit/short circuit to B+
    Intermittent
    Priority: 3
    Intermittent
    Priority: 3
    U103000 - Local data bus Electrical error
    static
    Date: 2021-02-02 22:11:06
    Mileage: 73505 km
    Priority: 2
    Malfunction frequency counter: 28
    B10AE29 - High pressure sensor Implausible signal
    static
    Date: 2021-02-02 23:56:17
    Mileage: 73505 km
    Priority: 2
    Unlearning counter: 245
    Dynamic environmental data: 26092AF40C0A26010026126A26500203
    U112100 - Databus missing message
    static
    Mileage: 73505 km
    Priority: 6
    09 Central Electrics
    System description: BCM MQBAB H
    Software number: 5Q0937084AE
    Software version: 0124
    Hardware number: 5Q0937084AE
    Hardware version: H16
    Serial number: 00011403500303
    ODX name: EV_BCMCONTI
    ODX version: 012001
    Long coding: 03111A46C24122F30BA44080B10C0728180000000000000000 0000000000
    Subsystems:
    System description: WWS 140131
    Software version: 0551
    Hardware version: 042
    Serial number: 140203083244
    Long coding: 0E4DDD
    System description: RLFS
    Software version: 0042
    Hardware version: 024
    Serial number: Y14M02D10H08M38S24S7
    Long coding: 00A8DD
    System description: Sensor, DWA
    Software version: 0315
    Hardware version: 005
    Serial number: 000000000ZY1401629BL
    System description: Sirene, DWA
    Software version: 0311
    Hardware version: 004
    Serial number: 00000000000028639685
    System description: J245 PS73.013
    Software version: 0007
    Serial number: WOO26784102
    Long coding: 181801
    Trouble codes:
    U10F600 - Rain/light recognition sensor No communication
    Intermittent
    Priority: 2
    Unlearning counter: 43
    Terminal 15 status: Off
    Terminal 50 status: Off
    Voltage: 12.7 V
    Outside air temperature: 26.0 °C
    Status Bremslichtschalter (HW): Off
    Status Bremslichtschalter (CAN): Off
    Off: not activated
    Parking light: not activated
    Automatic high beam assist: not activated
    Low beam: not activated
    Parking light left: not activated
    Parking light right: not activated
    Letzte Weckursache/ Werte [00;2E]: keine Störschutzursache
    CAN-Bus_aktiv: On
    U10F500 - Humidity sensor No communication
    Intermittent
    Priority: 2
    Voltage: 12.7 V
    Off: not activated
    CAN-Bus_aktiv: On
    19 Gateway
    System description: GW MQB High
    Software number: 5Q0907530Q
    Software version: 1164
    Hardware number: 5Q0907530F
    Hardware version: 125
    Serial number: 0001536145
    ODX name: EV_GatewLear
    ODX version: 010015
    Long coding: 030100042B085900EF00027E9C0F0001000100000000000000 0000000000
    Subsystems:
    System description: J367-BDMHella
    Software version: 8043
    Hardware version: H03
    Serial number: 6074762503
    System description: E221__MFL-DC1
    Software version: 0038
    Hardware version: H06
    Serial number: 29140000037310084043
    Long coding: 2DFFFF
    Trouble codes:
    U103B00 - A/C compressor No Communication
    Intermittent
    Date: 2021-02-16 19:11:20
    Mileage: 73726 km
    Priority: 2
    Supply voltage, terminal 30: 13.2 V
    Terminal 15: On
    U016400 - Lost Communication With HVAC Control Module
    Intermittent
    Date: 2021-02-16 18:46:40
    Mileage: 73726 km
    Priority: 2
    Supply voltage, terminal 30: 12.3 V
    Terminal 15: Off
    U105400 - Information electronics control module 1 No Communication
    static
    Date: 2021-02-15 19:58:35
    Mileage: 73722 km
    Priority: 2
    Unlearning counter: 3
    Terminal 15: On
    U140600 - Static current too high
    Intermittent
    Date: 2021-02-16 19:33:29
    Mileage: 73726 km
    Priority: 7
    Supply voltage, terminal 30: 12.4 V
    Terminal 15: Off
    hm....... lots of "aged" errors with low Malfunction Frequency counter numbers. Did you change the module on 02/02/21? Bulk clear the errors and re-post another scan copy - this time without any edits Don
    Feb 2021
    Sunbury, Victoria
    OBDeleven data log
    Date: 2021-02-18 09:21
    VIN:
    Car: Volkswagen Golf R
    Year: 2014
    Body type: 5-dr hatchback
    Engine: CJXB
    Mileage: 73726 KM
    01 Engine
    System description: 2.0l R4 TFSI
    Software number: 5G0906259B
    Software version: 0002
    Hardware number: 06K907425B
    Hardware version: H13
    ODX name: EV_ECM20TFS0205G0906259B
    ODX version: 001003
    Long coding: 091D00322466050B3004
    Trouble codes:
    No trouble codes found
    02 Transmission
    System description: DQ250-6A MQB
    Software number: 0D9300011R
    Software version: 4319
    Hardware number: 02E927770AQ
    Hardware version: H52
    Serial number: TFK01401280313
    ODX name: EV_TCMDQ250021
    ODX version: 001001
    Long coding: 0014
    Trouble codes:
    03 Brakes
    System description: ESC
    Software number: 5Q0907379AB
    Software version: 0557
    Hardware number: 5Q0907379H
    Hardware version: H31
    Serial number: 602440000000D3
    ODX name: EV_Brake1UDSContiMK100IPB
    ODX version: 033001
    Long coding: 01FA93A154292972037C070141C66980C92A94C0E08296F7F8 4250B8C208
    Trouble codes:
    08 Air Conditioning
    ODX version: 003018
    Trouble codes:
    static
    Date: 2021-02-18 09:10:01
    Mileage: 73726 km
    Priority: 2
    static
    Date: 2021-02-18 09:17:18
    Mileage: 73726 km
    Priority: 2
    Dynamic environmental data: 26092CF40C0026010026124726500002
    static
    Mileage: 73726 km
    Priority: 6
    ODX version: 012001
    Subsystems:
    Long coding: 0E4DDD
    Long coding: 00A8DD
    Long coding: 181801
    Trouble codes:
    13 Adaptive Cruise Control
    System description: ACC Bosch MQB
    Software number: 5Q0907572B
    Software version: 0200
    Hardware number: 5Q0907572B
    Hardware version: H04
    Serial number: 20011477030056
    ODX name: EV_ACCMRRBoschVW372
    ODX version: 001014
    Long coding: 001C1300FE0339
    Trouble codes:
    14 Wheel Dampening
    System description: DAEMPFUNGS-SG
    Software number: 5Q0907376
    Software version: 0115
    Hardware number: 5Q0907376
    Hardware version: H15
    Serial number: 16011441350291
    ODX name: EV_DRCONTITEMIC
    ODX version: 001019
    Trouble codes:
    15 Airbag
    System description: AirbagVW20
    Software number: 5Q0959655AA
    Software version: 0386
    Hardware number: 5Q0959655AA
    Hardware version: 014
    Serial number: 003MLR03GHG$
    ODX name: EV_AirbaVW20SMEVW37X
    ODX version: 002130
    Long coding: 98CCC000000000005C00000000C800000065
    Subsystems:
    System description: BeltPretRevFL
    Software version: 0341
    Hardware version: H35
    Serial number: 34169677B06021471049
    Long coding: 333135
    System description: BeltPretRevFR
    Serial number: 34169676B04021450287
    Long coding: 333135
    System description: SideSensor_Df
    Software version: 0887
    Hardware version: 001
    Serial number: 35767000000F1C6D9E0C
    Long coding: 2D2D2D
    System description: SideSensor_Pf
    Serial number: 35867000000165505E0M
    Long coding: 2D2D2D
    System description: SideSensor_Dr
    Software version: 6149
    Serial number: 3516502B113013F2A3D%
    Long coding: 2D2D2D
    System description: SideSensor_Pr
    Serial number: 3526502BB12AB1B2E22F
    Long coding: 2D2D2D
    System description: FrontSensor_D
    Serial number: 3556502C712FAE2522AM
    Long coding: 2D2D2D
    Trouble codes:
    16 Steering Column
    System description: Lenks. Modul
    Software number: 5Q0953507EC
    Software version: 0110
    Hardware number: 5Q0953549C
    Hardware version: 002
    Serial number: 03021404220849
    ODX name: EV_SMLSKLOMQB
    ODX version: 017001
    Long coding: 0C10
    Trouble codes:
    17 Dashboard
    System description: KOMBI
    Software number: 5G6920870B
    Software version: 2210
    Hardware number: 5G6920870B
    Hardware version: 314
    ODX name: EV_DashBoardVDDMQBAB
    ODX version: 008031
    Long coding: 27AD0818BF80000800886A01040000
    Trouble codes:
    19 Gateway
    ODX version: 010015
    Subsystems:
    Long coding: 2DFFFF
    Trouble codes:
    static
    Date: 2021-02-18 09:17:21
    Mileage: 73726 km
    Priority: 2
    Terminal 15: On
    22 All Wheel Control
    System description: Haldex4Motion
    Software number: 0CQ907554D
    Software version: 7076
    Hardware number: 0CQ907554D
    Serial number: HA1-00004.01.1400011009
    ODX name: EV_AllWheelContrHA1VW37X
    ODX version: 002001
    Long coding: 0001
    Trouble codes:
    2B Steering Column Lock
    System description: ELV-MQBA
    Software number: 5Q0905861A
    Software version: 0120
    Hardware number: 5Q0905861A
    Hardware version: H01
    Serial number: 14000014378002
    ODX name: EV_ELVMarquMQB
    ODX version: 004111
    Long coding: DD00000000000000
    Trouble codes:
    42 Driver Door
    System description: TSG FS
    Software number: 5Q0959593B
    Software version: 0025
    Hardware number: 5Q0959593B
    Hardware version: 020
    Serial number: 28011403111495
    ODX name: EV_DCUDriveSideEWMAXKLO
    ODX version: 006003
    Long coding: 003E12208001048000000000
    Subsystems:
    System description: FOND_FHSG_DRV
    Software version: 0005
    Serial number: 00000000000001779133
    Long coding: 1D0000
    Trouble codes:
    Feb 2021
    Sunbury, Victoria
    No the unit wasnt changed at that point. Apologies for just pasting all the text into the thread, havent been able to upload any files.
    no problem - that's better! When you replaced the hex08 module, did you replicate the long-code string and the adaptation channel values from the old module into the new module? - because the DTCs suggest that new module is missing data messages? Don
    Jul 2022
    Substate
    trom555 what was the issue with your Golf R?
