Results 1 to 9 of 9
Thread: Mk7 golf r
    Mk7 golf r
    Is there any way to find out what version of firmware / software my golf r DSG and ecu is running . It has always been serviced by private garages prior to my ownership and I’m curious to find out if there is a newer / updated software firmware available .
    Jun 2007
    Sydney, Australia
    OBDEleven will show you this if you do a full scan.
    Flipper Dog
    Now - T-Roc R, Audi Q5
    Okay done . Any one work for vw and can tell me if there is a revision / updated software firmware available
    Pacific Paradise QLD
    Quote Originally Posted by godzilla View Post
    Well what have you got so they can tell if there is a later one??????
    Hardware version h53
    Hardware number 02e927770aq
    Software version 4516
    Software number 0d93000012l
    VW will only update if it is faulty under what you have so you are more or less stuck with what you have
    It isn’t as clean down shifting from 4 to 3rd and sometimes into 2nd in d mode . Sport and manual mode it fine. Tuner friend said there might have been a software update to correct it . ( had the car a year and half and had always done it , never gotten worse , stayed the same )
    Was more hoping someone might work for vw might be on here and say yea there is a software update for that . Or na you wasting your time seeing the local vw dealer
    Nov 2007
    If you have a reasonable relationship with your local VW dealer, I'd suggest you go to them and ask them to check if there is a new version of the software. Most likely they will do it and update for you (likely at a cost) if you explain the symptoms. Try Austral VW in Breakfast Creek.
