Page 280 of 334 FirstFirst ... 180230270278279280281282290330 ... LastLast
Results 2,791 to 2,800 of 3333
Thread: Mk7 Golf GTI Discussion Thread
  1. #2791
    Mar 2009
    Quote Originally Posted by Splashalot View Post
    Ralfi, the anti-dazzle sensor is that small square cut-out on the left-most side (right side to the camera) on the back of the mirror. Your tag is well clear, so would have no effect.
    Yeah i'm aware it's the small square. Just wasn't sure how clear a degree of sight it needed (180 degrees, or just directly in front) for the anti-dazzle to work most effectively.
    Haven't really driven much at night, so can't say if it works yet - is the whole windscreen meant to drown out on-coming headlights as effectively as the rear-vision mirror does to those behind?
    & on the shaded area ("Communication Window" as the manual refers to it as), is non-coated (of infra-red reflective coating) which ensures that electronic accessories (remote controls) can function properly.
    ..."The uncoated area should not be covered either from the outside or the inside, nor should any stickers be applied to this area as this could cause a fault in the electronic components".
    MY16 MK7 Golf GTI
    - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
  2. #2792
    Apr 2011
    Quote Originally Posted by Ralfi View Post
    Our windscreens don't do this
  3. #2793
    Mar 2009
    Quote Originally Posted by Eaglehawk View Post
    Ok, so my concern (regarding blocking the sensor with etag) was for nothing?
    When you say 'our', do you mean GTI's/All Golfs? Ie. other VW models do have this feature?
    MY16 MK7 Golf GTI
  4. #2794
    Apr 2013
    My understanding was that the communication window was an area specifically with no metal or whatever so the tag registered properly. Mine has never not worked. Here's an old thread that I just googled
    Attaching eTag to windscreen?
  5. #2795
    Mar 2009
    Quote Originally Posted by Jimi View Post
    Thanks, Jimi.
    Looks like we can remove it completely since we have a metallic windscreen. & be charged 0.75 for the first time only without having it on display, but then have that refunded (which we need to arrange). All subsequent gate passes sans-etag holder won't be charged the 0.75 fee.
    I've stuck it too low, so will remove it & have an etag-free windscreen.........
    MY16 MK7 Golf GTI
  6. #2796
    May 2015
    Any idea when MY2016 Golf R will start shipping to Australia and will it have the MIB 2 display?
  7. #2797
    Can you over-ride the auto handbrake's insistence the seatbelt is on before it will release?
    Sorry don't know but today I discovered Auto-Hold doesn't engage unless your seatbelt is on.
    I'm sure there's a perfectly rationale explanation for this Mk7 Golf GTI Discussion Thread
    2014 GTI | Pure White | Manual | Sunroof | DAP | Dog sleeping on back seat |
  8. #2798
    Mar 2009
    Anyone not too impressed with the swirls on the glossy B-pillars & requested the dealer have them removed/swapped for others? How did this process go?
    You can kind of see the swirls here, but in the right light it seems as if the dealers detailers went to town on them without much care?
    Mk7 Golf GTI Discussion Thread-image-jpg
    MY16 MK7 Golf GTI
  9. #2799
    Oct 2014
    Queensland
    Yes having been with The Audi brand for many years those swirs irked me also, luckily my new MK7 GTi is swirl free , I put that down to the dealership not buffing the vehicle prior to delivery as many do for absolutely no reason other than to ruin the entire cars paintwork., not noticeable much if you have a white or silver car , but once you get into the dark colours it looks terrible. High quality waxes will essentially "fill" the swirls or scratcher , which is what they are and render them almost invisible , but of course everytime you wash your car you remove some of the wax , so eventually back to the swirls again, If i had had that issue I would have had a high quality "carbon fibre look" vinyl wrap applied PROFESSIONALLY.If it is done professionally with the best material , problem solved and looks good to0.
    Remember to always use clean cloths when washing and the best wash/polish products money can buy !My 2 cents worth !!
  10. #2800
    Jul 2012
    Quote Originally Posted by fastmk7 View Post
    Can I ask what dealer your car came from?
