Yeah i'm aware it's the small square. Just wasn't sure how clear a degree of sight it needed (180 degrees, or just directly in front) for the anti-dazzle to work most effectively.
Haven't really driven much at night, so can't say if it works yet - is the whole windscreen meant to drown out on-coming headlights as effectively as the rear-vision mirror does to those behind?
& on the shaded area ("Communication Window" as the manual refers to it as), is non-coated (of infra-red reflective coating) which ensures that electronic accessories (remote controls) can function properly.
..."The uncoated area should not be covered either from the outside or the inside, nor should any stickers be applied to this area as this could cause a fault in the electronic components".
MY16 MK7 Golf GTI
- Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
MY16 MK7 Golf GTI
My understanding was that the communication window was an area specifically with no metal or whatever so the tag registered properly. Mine has never not worked. Here's an old thread that I just googled
Attaching eTag to windscreen?
Thanks, Jimi.
Looks like we can remove it completely since we have a metallic windscreen. & be charged 0.75 for the first time only without having it on display, but then have that refunded (which we need to arrange). All subsequent gate passes sans-etag holder won't be charged the 0.75 fee.
I've stuck it too low, so will remove it & have an etag-free windscreen.........
MY16 MK7 Golf GTI
Any idea when MY2016 Golf R will start shipping to Australia and will it have the MIB 2 display?
MY16 MK7 Golf GTI
Yes having been with The Audi brand for many years those swirs irked me also, luckily my new MK7 GTi is swirl free , I put that down to the dealership not buffing the vehicle prior to delivery as many do for absolutely no reason other than to ruin the entire cars paintwork., not noticeable much if you have a white or silver car , but once you get into the dark colours it looks terrible. High quality waxes will essentially "fill" the swirls or scratcher , which is what they are and render them almost invisible , but of course everytime you wash your car you remove some of the wax , so eventually back to the swirls again, If i had had that issue I would have had a high quality "carbon fibre look" vinyl wrap applied PROFESSIONALLY.If it is done professionally with the best material , problem solved and looks good to0.
Remember to always use clean cloths when washing and the best wash/polish products money can buy !My 2 cents worth !!
