The GTI PP is a couple of weeks old and just covered over 500km.
Some little issues that have arisen.
In Normal mode, DSG gets into 5th gear at less than 50kph, so the car then labours along, then when you accelerate, sounds like diesel..
Over the weekend I have discovered that the Mk6 wastegate rattle affects the Mk7 too - presume the solution is the attachment of the clip.
Today the most annoying 'rattle' has raised itself. When the car is accelerating during normal driving (in normal mode) there is a buzz which sounds like a Geiger counter when around 2000rpm-3000rpm from behind the instrument display. Overseas forums reckon it could be a loose soundkator? Anyone experienced it?
So went to the dealer today, booked in for both vibrations, fortunately the VW tech was able to hear the noises ( the second one will be a challenge - VW will only pay for rattles/vibrations under warranty if the car has covered less than 1000km....so if you find any, book it in before you get to 1000km.
