Page 9 of 9 FirstFirst ... 789
Results 81 to 89 of 89
Thread: Mk7 Golf DSG Gearbox Issues, Questions and Discussion
  1. #81
    Jan 2016
    Thanks for the response Lucas - I'm not convinced that it's mechanical. I expect it would have the issue every time at that load level, but it's only doing it once every 10 or 15 changes (maybe more), the other 14 are silky smooth as expected - the difference is chalk and cheese.
    My Mk5 Jetta DSG turbo and Mk6 GTI DSG never had the issue I'm describing here, although they did have that tramp / shudder when really launching the cars at the edge of traction.
    Mk7 GTI Performance DSG Carbon Steel Grey
  2. #82
    Sep 2016
    I've got the same issue on my car, MY16 GTI Performance. Same as what you explained and for me occurs about every 10 shifts in manual mode. Sometimes it happens twice in a row too. I've got a 034 torque mount I'm waiting to install so when I do I'll let you know if it changes anything.
  3. #83
    Jan 2016
    Thanks Mike, I'll be keen to know. Have you spoken to VW about it?
  4. #84
    Sep 2016
    Sorry to hear about the issues. Have you tried taking it back to the dealer to check?
    If I recall correctly, my MY16 GTI would do the same from 1st to 2nd very early on... Drove me insane! After trying various things, I managed to replicate the issue. Basically, if auto stop-start was activated + the engine turns off while you're at a stand still, on restarting the shift would be harsh - guaranteed. The solution was to make sure stop-start was deactivated when in manual mode. Never had that problem since.
    Not sure if it's the same issue you guys are experiencing but I thoughts it's worth sharing
  5. #85
    Sep 2016
    Quote Originally Posted by Danoman View Post
    Just got back from a drive and experienced it again, I can confirm it does happen after the engine stops and then starts while in manual; shifting between 1st and 2nd. Haven't driven long enough to see if it happens with stop-start off though. Strange that this happens. Has VW released anything on this at all? Or is it just something expected for our vehicles?
  6. #86
    Jan 2016
    Thanks guys, I'll give it a try. If it's 100% replicable it's probably worth taking to VW.
    Oh, and thanks mods for merging my new topic with this one.
  7. #87
    Jan 2016
    So, I can confirm what Danoman and Mikeau described, it happens after a restart from the stop - start system, and happens about 90% of the time in that circumstance.
    Has anyone had any luck discussing this with VW?
  8. #88
    Jun 2011
    Queensland
    MY15 to MY16 DGS Changes?
    Hi guys,
    Just drove a MY16 golf 92TSI DSG and found it was a completely different drive to my existing MY15 golf. It provided a smoother drive, was less clunky, had a lot less engine braking when applying brakes going downhill and also a lot less vibration at lower speed.
    Have there been any changes between the DSG in the MY15 to the MY16? I've heard a rumor that they changed to wet clutches in the MY16 but I haven't seen that written/referenced anywhere. Have most of the DSG issues been ironed out in the MY16/MY17 models?
    Thanks
  9. #89
    Nov 2009
    Quote Originally Posted by sangers View Post
    The 92TSI still uses the same 7-speed dry clutch DSG it did before. Although there may have been minor changes to part numbers and software/firmware versions of controllers, the gearboxes themselves should be otherwise identical. What you're describing is not unusual of the DSG - it can be quite susceptible to 'bad behaviour' depending on how it's driven/treated and can become recalcitrant over time. If you've having issues with yours (inc clutch vibration), check out The Official Mk7 Golf DSG / Clutch / Shudder / Squeal Issues Thread.
