Results 1 to 10 of 10
Thread: Mk7.5 reversing guide lines
    Blackburn South, Victoria
    Just a question that someone may know. I have the static green reversing guide lines on the golf. Can they be changed (vcds or obd11) to be the dynamic turning guide lines like in my passat? Cheers.
    2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
    2023 MY23 Nevada White Cupra Formentor VZx
    2015 Carnival Yellow Honda S660
    Feb 2018
    This is a frustration of mine.. hoping it's possible, however am sure it likely programmed with the steering wheel and as the lock to lock ratio is shorter it might be an issue? Hoping someone with more knowledge chimes in
    Sent from my SM-N950F using Tapatalk
    Quote Originally Posted by Grugly View Post
    I have a feeling it might be hardware and the dynamic lines turn with the steering wheel. On the web, there seems to be mention of a highline RVC and lowline RVC...
    Apr 2011
    When the picture of m car comes up on the Centre screen with the parking sensors, the yellow swept path curves both front and rear when I turn the steering wheel, so don’t really see why the camera can’t do it.
    MY18 Golf R 7.5
    Feb 2018
    Quote Originally Posted by Rocket55 View Post
    Good point
    well i had a look at the RVC on my golf in the equipment list. It comes up as "With rear view camera system (type 1)". on my passat which has the moving guidlines it is "With rear view camera system (type 2)". So i think it is hardware dependant.
    Nov 2017
    Coffs Harbour NSW
    That's a bummer. A base level i30 has dynamic lines, but not my 2018 GTI.
    Still the GTI parks itself, so I guess that's something.
    2018 Golf GTI DSG (DAP LUX INFO R-TAILS)
    Maribyrnong, Victoria
    The camera is different and also the loom.... you have to run a new loom to the BCD.
    Nov 2018
    2019 Golf R specs states: "Rear View Camera (RVC) with static guidance lines"
    Nov 2017
    Coffs Harbour NSW
    Golf R drivers don;t even need a reverse camera let alone bendy lines.
    Save the bendy lines for the i30s
