Originally Posted by
DreamensioN
Hey guys - posting in here because it's a lot more active than the CC/Arteon thread - but I've got a question.
Those of you with the Golf GTI/R - when you bring up your digital performance gauges (boost, oil temp, Kw etc) - what does your boost read when you're off throttle or the car is idle? In the Arteon I'm always reading positive pressure whether the car is idle, or if I'm coasting. I'm not sure if this is normal as in previous cars that have had mechanical boost gauges that were tapped into the plenum, off throttle was always a negative pressure.
So my 2 questions are - is anybody having the same experience as me, and, does anybody know why it always reads positive pressure?
Yep - that's not an error - all our cars read about 0.2-0.3 bar at idle. The boost gauge reads absolute pressure. So, if the chamber containing the gauge was completely open to the atmosphere the value would read 1 bar, or around 13PSI - this being atmospheric pressure at sea level. So any number below this means the engine still has to suck it's air though the intake channels. Meaning the boost being generated by the turbo, in Golfs at least, is represented by the difference over 1.0 bar.
One of the popular reviews on the R got this wrong (performancedrive.com.au from memory) claiming the turbo on the R was generating a "ballistic" 27 pounds of boost, and even put it down as a possible negative for the car's long term durability. They were obviously looking at the absolute boost from the centre console display.
Wouldn't it be good if they were, though.
2017 - Golf R 7.5 - Blue - DSG - Proper Roof - DAP - Res' delete - Dynaudio delete
2008 - Mazda 2 - (Maybe my first child scared me a bit) -1998 - Wrx (modded up to but not including forged pistons)
1988 - Corolla TwinCam - (couldn't insure a 323 Turbo)
1967 - Tonka Tip Truck - Red with 2 inch plastic rims and a massive sand scoop.
