Page 118 of 122 FirstFirst ... 1868108116117118119120 ... LastLast
Results 1,171 to 1,180 of 1215
Thread: Mk7.5 Golf - News and Discussion Thread
  1. #1171
    Jun 2017
    VIC
    Quote Originally Posted by notaGolfR View Post
    I drove 300 metres from cold every morning
    too far to walk?
    If you are anal you could measure your oil before and after driving oil at 100 degrees plus and get an idea about how cruel you are being to oil with short cold trips
    You'll find that during a short trip the oil will struggle to get to 100 degrees, the damage is done on the way up to 100 degrees. The water issue would then be secondary to that. The primary issue would be the lack of viscosity in the oil at those low temps.
  2. #1172
    Jun 2017
    VIC
    Quote Originally Posted by Call me Al View Post
    when I take off pull back to R for take off.
    When driving in Normal then pulling back, does it put the gearbox only in sport or the suspension and dampers too?
  3. #1173
    Canberra
    Quote Originally Posted by roh008 View Post
    The gear lever only changes gearchanges (DSG) from D to S or M, it has no effect on DCC suspension (but S mode engine is more responsive as it keeps the revs higher).
    Dampers (and engine response, soundaktor, exhaust valves if fitted etc) is changed by driving modes: Normal, Individual, Race or [wash your mouth out with soap] Eco.
  4. #1174
    Dec 2018
    S.A.
    Smile
    too far to walk?
    [/FONT][/COLOR]
    In my defence I should say that I often had to make deliveries from work during the day so I needed the car at work. In my further defence, after work I would go to the pub & it was only 50 metres so I would walk there and when I got back I would push the car home because I'd had a few.
    As with the coolant system, does the oil system have a system to make it heat up quickly? The coolant system is easily the best I have ever had as it gets to normal in under 5 minutes but the oil temp takes 15 minutes (on a 15 degr. celcius day) to start registering when it shows 50 degrees celcius. The owner manual says to wait until that happens which is frustrating. In winter, can I blank off an oil cooler somewhere and rely on the coolant system to keep oil temp under control?
    cars (chronological) Morris850, Morris Mini DeLuxe, Cooper S, Mazda 1500SS, hard times so some old Holden, old Falcon Ute, better times so second hand Lotus Elan +2 (6 weeks, hopelessly unreliable) Chrysler Valiant Charger 770, second hand Datsun 260Z + 2 auto, Mitsubishi Cordia Turbo, Nissan 200SX turbo auto for 20 years(wonderful car burning ZERO oil after 200,000km & no problems when sold.. should have kept it), Toyota GTS 86 auto, now Golf R Mk 7.5 DSG built Aug2018, white.
  5. #1175
    Apr 2019
    CANBERRA, Australia
    Quote Originally Posted by kennyc View Post
    Hi all, question.
    There is someone at my golf club (don't know the person) who has a MK7.5 White Golf R. It looks like the car has a moon roof, not a panoramic roof. The black glass roof goes all the way to the rear spoiler. I don't think this is available in Australia is it not?
    Just curious as I look the look of it. All the cars I have seen with the sunroof have like only half the roof as the black glass, not the full roof....
    It is the 4 door hatch as well btw.
    Which city you in ?
  6. #1176
    Aug 2019
    Tasmania
    I have a 2018 Golf R Grid, are the timing belts rubber or chain?
  7. #1177
    Jul 2018
    Camden Sydney
    Quote Originally Posted by Mitch204 View Post
    Chain EA888
  8. #1178
    Aug 2019
    Tasmania
    Quote Originally Posted by tw586 View Post
    Chain EA888
    Thank you! Service manual mentions toothed belt
  9. #1179
    Apr 2019
    Coffs Harbour
    My Golf R SE has a buzzing type rattle emanating from the triangular black plastic moulding just behind the interior rear view mirror which I believe houses the lane guidance sensors. It occurs under acceleration and disappears if I put my finger on it. Has anyone else had this issue. Obviously it’s still under warranty but any info I can give the dealer would be handy. Cheers.
  10. #1180
    Apr 2014
    The Monash Freeway
    Quote Originally Posted by Fangbosun View Post
    Mine too.
    Ben
    Current: ‘19 VW Golf R
    Past: ‘05 RS 225 Cup
    Ben
    2015 Polo GTI & 2019 Golf R
