Page 117 of 122 FirstFirst ... 1767107115116117118119 ... LastLast
Results 1,161 to 1,170 of 1215
Thread: Mk7.5 Golf - News and Discussion Thread
  1. #1161
    Canberra
    Quote Originally Posted by Call me Al View Post
    The other thing I noticed is the peel in the paint finish is too noticable for my liking. Not a deal breaker but all factory finishers could do better.
    l
    I've also got lots of "orange peel" in the paint on my Oryx White wagon. I instructed my detailer to go easy on the the polishing as I didn't want to lose too much clear coat. I did find a final layer of Lustre improved the gloss quite a bit.
  2. #1162
    Jul 2019
    Quote Originally Posted by gregozedobe View Post
    Thanks Greg,
    If that is the only thing to complain about we are ok!
    I love the Boring Pure White after the Black Magic Gti!
    Oh another observation is the Floor Mats that came with the R are inferior quality to the 2008 Gti floor mats.
    Cheers Al
  3. #1163
    Canberra
    Thanks Greg,
    Cheers Al
    Yeah, not a lot really wrong with a Golf R wagon Wolfsburg. Not to say I couldn't suggest some improvements, but the overall package is pretty good (and so it should be at the money VW asks for them).
    I put some "rubber" (more plastic) floor mats by 3D in mine, as I sometimes get in with muddy boots.
  4. #1164
    Jul 2019
    Great minds think alike Greg.
    'I put some "rubber" (more plastic) floor mats by 3D in mine, as I sometimes get in with muddy boots.'
    I have a set of Rubber Mats in mine too.
    Cheers Al
  5. #1165
    Jun 2017
    VIC
    Hi Folks,
    So we did the first 400 ks in the R wagon and the BP fuel for 98RON was 145.9 per liter.
    Filled up and averaged 10 liters per 100 s. So did I expect easy 5's like the Polo Gti. no! Pretty good for a new car, run in period where I first warm the engine and DSG up before driving it hard!
    One thing we both noticed is the leather on the steering wheel, while it is high quality, does not match our old 2008 Polo Gti perforated leather wheel.
    The Nav is much much better than the Subaru Forrester.
    Still have yet to read through the Hand Book. Should be interesting.
    Cheers Al
    I just picked up my brand new wagon, had 30ish kms (i had put 6-8kms on the test drive). now at 300kms daily commuting I get around 8l/100 not pushing it that hard.
    I noted that keeping it in 'S' increase stationary RPMs by 300 to above 1000RPM at idle, so essentially any driving in Sport mode would easily add .5-1L/100
    I like the steering wheel feel but I too think it might not still be like that after a year or so
  6. #1166
    Jun 2017
    VIC
    Cheers Al
    Can you recommend where to buy a cost effective set?
  7. #1167
    Canberra
    Quote Originally Posted by roh008 View Post
    I'm not sure what you regard as "cost effective", but I bought mine for $149 + $15 shipping from trufitcarpets on ebay, but they no longer have a current listing for these. I was happy with the quality and see them as good value as 18 months later they are still going strong.
    To suit VW GOLF Mk7 2013 to 2019 -BLACK RUBBER 3D Car Mats | eBay
    Edit: Looks like 3D are only making rubber mats for Amaroks these days, none for Mk 7 Golfs anymore (according to their website, anyway)
  8. #1168
    Jul 2019
    Hi roh008,
    I noticed the D versus R and prefer to let it idle in D then when I take off pull back to R for take off.
    In D the DSG takes off in D2 but in S mode it takes off in S1. You are taking care to run the R in?
    Ben T posted his running in routine. I agree it's a good way to run it in.
    My running in procedure has always been to get the boost up but not redline it for the first 1500, and use manual mode so it doesn’t cruise around at minimum revs either. Worked well for my 1.4 Polo GTI which used no oil whatsoever.
    Is the Gav you mentioned from Underground Performance? If so, he services my VWs.
    Ben
    Current: ‘19 VW Golf R
    Past: ‘05 RS 225 Cup
  9. #1169
    Jun 2017
    VIC
    it has crept up to redline a few times but I quickly lift of or shift up a gear. I don't hold it up at the redline for any period of time.
    in the daily commute there is enough variation in driving between stop start and constant speed. When I get bored I do a few pulls but to be honest, i've gone way to quick without paying attention to the speedo.
    Do we know why in sport it idles at 1000/1250Rpm?
  10. #1170
    Dec 2018
    S.A.
    I have never had an oil temperature gauge before so I turned it on out of interest. [On the infotainment screen press Menu/Vehicle/ Selection (in the lower LH corner) / Sport]. I bet you would never guess those steps! If necessary press an arrow to show the instruments instead of the Lap Time display or, If necessary, swipe an instrument up (or down) to show the Oil Temp .
    When I went for a drive it took ages to register a temperature, but eventually it got up to show 100 degrees C. At that temp. It dawned on me that is the boiling point of water (at normal atmospheric pressure). Therefore I thought that if I keep the oil above that (since the oil pressure will be raising the boiling point ….. correct me if I’m wrong) the water in the oil, which forms normally from condensation, will boil off. That’s a good thing as the water rots the engine metal. Also, measuring your dipstick oil level will show actual oil and not oil+water. If you are anal you could measure your oil before and after driving oil at 100 degrees plus and get an idea about how cruel you are being to oil with short cold trips.
    I am red hot on water in the oil because 50 years ago when I was more ignorant I wore out a brand new car engine in 2 years because (despite oil changes by the book) I drove 300 metres from cold every morning and the car sat there all day except for the odd delivery some days.. Then 300 metres (not MILES or KM) back home where it sat overnight. I was always puzzled by stuff like mayonnaise inside the oil-filler cap doh!
    cars (chronological) Morris850, Morris Mini DeLuxe, Cooper S, Mazda 1500SS, hard times so some old Holden, old Falcon Ute, better times so second hand Lotus Elan +2 (6 weeks, hopelessly unreliable) Chrysler Valiant Charger 770, second hand Datsun 260Z + 2 auto, Mitsubishi Cordia Turbo, Nissan 200SX turbo auto for 20 years(wonderful car burning ZERO oil after 200,000km & no problems when sold.. should have kept it), Toyota GTS 86 auto, now Golf R Mk 7.5 DSG built Aug2018, white.
