Is it possible to disable this via VCDS/OBD11?
ACC is slowing down not to overtake using right lane - which is allowed in my country.
Which channel is that? I can only see something like Predictive speed limit regulation.
That only puts a tick box in the acc menu, I think the guy meant long coding not adaptions, there is a lane change support and a overtaking assistance and a overtaking right prevention settings in there, not sure what they do
What at does it do, does it cancel braking if you put the indicator on?
It slows down. Stops slowing down if i push accelerator or res button.
What's the bit and byte for overtaking right protection? I dont have description in vcds.
that any help
Thank you, all I need!
My Arty has this problem too ...slowing down on ACC for no apparent reason other than traffic to the right of me on the freeway on intermittent occassions on straight roads until i give the go pedal a boot
Sent from my SM-G935F using Tapatalk
